Hold 'Em (English)
Info: This is the Hold 'Em that was successfully repatched for alky by our friend AMIRZ (thnx). It includes Alky for Applications and it already installs unattended with the data.bin (thnx to kontini for this) that is necessary for the Windows Ultimate Extras and Alky.
http://www.mediafire.com/?zyececahpkylalc
MD5: 756D0EA2F64C93A9D45BFAA5D84EF7E9
Website: http://www.wincert.n...?showtopic=4069
Ultimate Sounds (English)
Info: Includes the Ultimate Extras sound shemes from Vista: Microsoft Tinker, Glass and Pearl. Also replaces the original Windows XP sounds with those from Vista
Important: IF YOU DON'T INSTALL HOLD 'EM ALONG WITH THE SOUNDS THE SCHEMES THEY WILL NOT BE INSTALLED, SO YOU HAVE TO INTEGRATE THEM TOGETHER.
http://www.mediafire.com/?wes9ye9g88nadfr
MD5: 43C78FFF50CF882FC11AF243D70F60E4
How to (add)remove
You can (add)remove these addons by way of Add Remove Windows Components, look for them in Windows Ultimate Extras example:
Extract the sound pack and change the following in ultsound.inf
Parent			= UltExtras
To
Parent			= AccessUtil	; Accessories and Utilities
So it will no longer be dependant on Hold Em
hello ricks
back to my questions
this install Data.bin
it seems to run Holdem Only
what about other stuff does i still need my own Data.bin
or modify the Install Files to install my own Data.bin
alot of questions plenty of time to answer :P
thx for the addons and waiting for the answers
skrell, instead of AccessUtil use AccessTop (you will find these in ACESSOR.INF in your XP CD)
That will put it in Accessories and Utilities->Accesories in add or rem windows components, the first would have just put it in Accessories and Utilities
DaRk you can use 7zip archive splitter to un-compile the 7zip sfx and edit the config.txt and then recompile it
Would it be possible to just extract all the .wav files to the Windows\Media folder (perhaps in subfolders, a folder per scheme) and run the inf file for the reg entries?
This is the way I have always integrated vista sounds (I remove the original sounds).
Edited by zilexa
I noticed the sounds used when you select the default scheme, are totally different from the original Windows Vista soundscheme I used. (from the link in my previous post). Can you add these to your addon? I tried adding them but it got kinda messy since in that pack, those sounds are also set as default sounds :S
Edited by zilexa
If you look in txtsetup.sif you can see what sounds are what, these are the ones you will have to replace:
XPBalln = "Windows XP Balloon.wav"
XPBatCrt = "Windows XP Battery Critical.wav"
XPBatLow = "Windows XP Battery Low.wav"
XPBlkPop = "Windows XP Pop-up Blocked.wav"
XPCrtStp = "Windows XP Critical Stop.wav"
XPDef = "Windows XP Default.wav"
XPDing = "Windows XP Ding.wav"
XPError = "Windows XP Error.wav"
XPExcl = "Windows XP Exclamation.wav"
XPHdFail = "Windows XP Hardware Fail.wav"
XPHdInst = "Windows XP Hardware Insert.wav"
XPHdRem = "Windows XP Hardware Remove.wav"
XPInfBar = "Windows XP Information Bar.wav"
XPLogoff = "Windows XP Logoff Sound.wav"
XPLogon = "Windows XP Logon Sound.wav"
XPMenu = "Windows XP Menu Command.wav"
XPMin = "Windows XP Minimize.wav"
XPNotify = "Windows XP Notify.wav"
XPPrint = "Windows XP Print complete.wav"
XPRecycl = "Windows XP Recycle.wav"
XPRestor = "Windows XP Restore.wav"
XPRingin = "Windows XP Ringin.wav"
XPRngout = "Windows XP Ringout.wav"
XPShutdn = "Windows XP Shutdown.wav"
XPStart = "Windows XP Start.wav"
XPStartU = "Windows XP Startup.wav"
  • 5 months later...
  • 7 months later...
