Posted (edited)
PowerArchiver 2007 v10.2.1.17
What's New
Version 10.2.1.17 [December/2007]
Improvements:
* Improved speed of loading and closing when in modern interface.
* Updated SFTP engine for better performance.
* Added snap-to/default action mouse support.
Bug Fixes:
* Fixed Bug #83: D&D into empty PA window does not work.
* Fixed Bug #81: D&D folders with specific characters does not work.
* Fixed Bug #75: Titlebar truncated when not needed in Modern toolbar.
* Fixed Bug #74: Incorrect maximize state if taskbar is vertical.
* Fixed Bug #71: Associate does not work in Windows 2000.
* Fixed Bug #73: Extracting ISO files under Vista.
* Fixed Bug #77: Interface selection screen does not work under Win98.
* Fixed Bug #27: D&D out of archive - paths not respected
* Fixed Bug #56: Modern toolbar shows empty buttons.
* Fixed Bug #55: Skins can be enabled for Modern via configuration.
* Fixed Bug #67: Plugins do not work properly.
* Fixed Bug #60: Issues with TAR+99 characters.
* Fixed Bug #64: Strange FTP progress bar behavior.
* Fixed Bug #66: Updating ZIP PAE file shows zip encryption error.
* Fixed Bug #58: SFTP does not work with files over 100 MB.
* Fixed Bug #57: Improved installation of GDI+ on Win98/NT.
* Fixed Bug #68: Always use queue did not always ask for overwrite.
* Fixed Bug #69: Freeze if extracting file. when same name exists as folder
* Fixed Bug #70: QAT position does not get saved.
* Minor other fixes and improvements.
Information: Info
Version: 10.2.1.17
File Release Date: November 30, 2007
Addon Release Date: December 6, 2007
Silent Switch Used: /qb-!
Installs From: svcpack.inf
Credit: Reaper (aka Makave2345 or Me)
RyanVM Integrator Addon:
Main: Download
Mirror: Download
MD5: D345509BD9156BF8723FD38019303AAB
SHA1: E352FFA5AFD3195F72716B4527AB31568324BFAD
CRC-32: 7188004C
Switchless "Silent" Installer:
Main: Download
Mirror: Download
MD5: CE59DBFC92ED36CB1DD05A2BDB4104BE
SHA1: 316E0D2EA469B0430F9461FA878A028657338F65
CRC-32: 50E19786
NOTE: The first time you run the program you can enter your registration code
or you can choose to use this as a 30 day trial!
ENJOY!
Edited by Makave2345
For all other that wont to register the app here is registry entrie:
[HKEY_CURRENT_USER\Software\PowerArchiver\General]
"Regname"="NAME"
"Regnumber"="SERIALNUMBER"
Just replace NAME and SERIALNUMBER with your and you are ready to go ;)
new version of this software: 10.11 if u want to make it as a swtichless installer... I wouldn't mind... ;)
btw for the registry info is this what i do in an .inf: :icon_question:
[Version]
Signature=$Windows NT$
[Optional Components]
PwrArch
[DefaultInstall]
OptionDesc ="Registry Entries"
Tip ="Registry Entries"
Modes =0,1,2,3
AddReg =REGEntries.AddReg
[PwrArch]
Modes =0,1,2,3
[REGEntries.AddReg]
HKCU,"Software\PowerArchiver\General","Regname",0,"NAME"
HKCU,"Software\PowerArchiver\General","Regnumber",0,"SERIAL"
i basically just ripped it from ultra iso and just renamed it to go with powerarchiver.
