EVEREST Ultimate Edition v5.50.2100
Info: Windows Sidebar Gadget is included, enabled and installed... Also the Control Panel Shortcut is also turned ON by default.
Registration: To have a fully registered version of EVERST Ultimate simply unpack the AddOn and also the .CAB archive inside and replace the DUMMY pkey.txt with yours and then simply repack it as it was before.
http://www.mediafire.com/?tdoocokqq23djzt[\code]
[b]MD5:[/b] 66b9af042a4ad505567d74b6d4aa3611
[b]Website:[/b] http://www.lavalys.com/
[b]Changelog:[/b]
[size=1][b]04/20/2010[/b]
- Updated [b]v5.50.2100[/b]
[b]10/05/2009[/b]
- Updated [b]v5.30.1900[/b]
[b]6/20/2009[/b]
- Updated [b]v5.02.1750[/b]
[b]4/01/2009[/b]
- Updated [b]v5.01.1700[/b]
[b]2/09/2009[/b]
- Updated [b]v5.00.1650[/b]
- Created INF uninstaller for multilingual removal and display
[b]9/06/2008[/b]
- Updated [b]v4.60.1500[/b]
- Now sets default language (supported: engilsh, german, spanish, french, italian, dutch, turkish, chinese)
[b]3/21/2008[/b]
- Updated [b]v4.50.1330[/b]
- Control Panel Shortcut is now [b]ON[/b] by default
[b]10/22/2007[/b]
- Updated [b]v4.20.1170[/b]
- Sidebar Gadget is now installed and enabled by default[/size]
  • Replies 63
  • Views 45.1k
Hi Rick,
Pardon the stupid question... how do I repack the CAB file after putting my key in the file?
Thanks!
You can use any archiver that compress files to .cab, I personally use Power Archiver :)
If you have CabTool (that comes in Kels Uber pack) you can right click the Folder and SenTo CabTool and it will make a cab file with the same name as the folder
Personally I use TUGZip
Rick is it possible to improve sidebar engine for this addon so you dont' have to turn on program every time you run gadget? Is it possible configure it somehow so it would use everest engine and read values directly on gadget? Other than that gadget works perfect including addon :)
I dunno sorry
  • 5 months later...
  • 4 months later...
Hi! thank you for the great work!
I've chenged the dummy key with my valid key (valid)! then i've tried to install (using the inf.) and it went well but it ain't get valid, it splashes as the trial version and asks to buy it... again :(
Does anyone had this "problem"?
OK you are doing it via manual install... You should know that for this to install correctly manually you have to 1st copy EVERES.inf to %WinDir%\inf
hum... ok then! thanks! ^_^ sorry very newbie this side ;)
Gonna tried that way then!
Hi rick, would you be kind enough as to tell me the safest way to remove the start menu shortcut? I know its an entry in the inf file but im not sure what to do with it exactly. Thanks.
Edited by kronik
OK this will leave only the CPL shortcut... Just delete both these lines in the INF (there are 2)
ProfileItems=EVEREST.AddShortcut,Help.AddShortcut,Uninstall.AddShortcut
- Updated v4.60.1500
Now sets default language (supported list in the changelog)
