^SoKoOLz^ Posted May 5, 2007 Posted May 5, 2007 (edited) The request fromHERENormally, I've packed this with my Theme Addon ^^.This is a Vista RTM LOUD Sounds Scheme version since the original one is too soft.I've also added in 2 hidden sounds in Vista RTM for minimizing and maximizing the window.MD5: 6DAB5BD26CA333739185B695B6EA50DDSIZE:4.25 MBUpdated: 27/02/08- Change Startup Sound to the RTM version (requested by dareckibmw)- Remove Minimize and Maximize windows sound Reg entries (annoying for some ppl)Updated: 24/11/07- Fixed missing Startup sound- Remove Minimize and Maximize windows sound Reg entries (annoying for some ppl)Updated: 09/05/07- Fixed RAR SFXIf you want the True Addon version, PM me ^^ Edited February 27, 2008 by ^SoKoOLz^ Quote
ricktendo Posted May 5, 2007 Posted May 5, 2007 Thanks for this one sKz... Moved topic to SVCPACK section Quote
yadzil Posted May 6, 2007 Posted May 6, 2007 Great sKz. Thanks a lot to both of you. I'm going to try this. Quote
bober Posted May 7, 2007 Posted May 7, 2007 how come u didint make ure sfx like this?Path=%windir%Setup=regedit /s sKzVistaUltimateSound(Loud).regSilent=1Overwrite=1 Quote
^SoKoOLz^ Posted May 8, 2007 Author Posted May 8, 2007 (edited) @boberSorry, I made this a while ago. I will fix it thx.*It has been fixed Edited July 6, 2007 by ^SoKoOLz^ Quote
JuMz Posted June 28, 2007 Posted June 28, 2007 I like this addon with the exception of the minimize / maximize being enabled...by default, on windows installations, this sound is not set...Is is possible to remove those? Quote
chaox2 Posted November 13, 2007 Posted November 13, 2007 hai.. your loud sound isn't complete.missing Start Windows filedo you have louder Start Window's sound? Quote
baby huey Posted November 15, 2007 Posted November 15, 2007 yes there missing "Windows Startup Sound" :sad02: Quote
MzQueenie Posted November 19, 2007 Posted November 19, 2007 yeah start up sound is missing, anyone could fix it with a new addon to it? Quote
Kelsenellenelvian Posted November 19, 2007 Posted November 19, 2007 Sure provide me the start sound and I will update it. Quote
chaox2 Posted November 20, 2007 Posted November 20, 2007 http://d.turboupload.com/d/2155168/Vista_SystemStart.wav.htmlthis is vista start windows, i got fom ricktendo64's add on Quote
MzQueenie Posted November 20, 2007 Posted November 20, 2007 ^ how do you add it into the system automatically? Quote
MzQueenie Posted November 22, 2007 Posted November 22, 2007 Sure provide me the start sound and I will update it.thank you :happy: Quote
^SoKoOLz^ Posted November 22, 2007 Author Posted November 22, 2007 oh crap..This is for a while now....I wil update it soon, sorry guys. Quote
MzQueenie Posted November 22, 2007 Posted November 22, 2007 oh crap..This is for a while now....I wil update it soon, sorry guys.i thought you forgot about your own thread :happy: btw thank you when the update comes :thumb: Quote
kant Posted November 27, 2007 Posted November 27, 2007 missing Start Windows filedo you have louder Start Window's sound skz :crying_anim02: ? Quote
FXG Posted August 1, 2008 Posted August 1, 2008 :thumbsup_anim: :thumbsup_anim: Thanks Dude! :prop: :prop: Quote
