ricktendo Posted November 26, 2012 Posted November 26, 2012 About: Rebuilt (nothing removed) .NET Framework 4.5.2 Full x86/x64 installers including ALL updates (and Language Packs) integrated. For command-line options run <installer_name>.exe /? Note: Don't let the large size of the installer deceive you, using this installer saves 108 MB of disk space vs the original installer. The reason the installer is larger & saves disk space is because of better compression of the MZZ/CAB, when it comes time to rebuild the installer the maximum compressed (LZX:21) CAB will not shrink as much as the default non compressed one. OS: Windows Vista/Server 2008 SP2 x86/x64 or Windows 7/Server 2008 R2 SP1 x86/x64Rebuilt Microsoft .NET Framework 4.5.2 Full x86/x64 Download: http://adf.ly/1713566/dotnet451rpck Size: 97.6 MB MD5: cd10ddbc64b06f57d143d5c11b6ea47e Rebuilt Microsoft .NET Framework 4.5.2 Full x86/x64 Incl. Language Packs (ARA CHS CHT CSY DAN DEU ELL ESN FIN FRA HEB HUN ITA JPN KOR NLD NOR PLK PTB PTG RUS SVE TRK) Download: http://adf.ly/1713566/dotnet451intrpck Size: 284 MB MD5: 06cd3fc0fc190631297c969ddaf713ac Individual Rebuilt Language Packs: Arabic: http://adf.ly/1713566/dotnet451arrpck Chinese (Simplified): http://adf.ly/1713566/dotnet451chsrpck Chinese (Traditional): http://adf.ly/1713566/dotnet451chtrpck Czech: http://adf.ly/1713566/dotnet451csrpck Danish: http://adf.ly/1713566/dotnet451darpck Dutch: http://adf.ly/1713566/dotnet451nlrpck Finnish: http://adf.ly/1713566/dotnet451firpck French: http://adf.ly/1713566/dotnet451frrpck German: http://adf.ly/1713566/dotnet451derpck Greek: http://adf.ly/1713566/dotnet451elrpck Hebrew: http://adf.ly/1713566/dotnet451herpck Hungarian: http://adf.ly/1713566/dotnet451hurpck Italian: http://adf.ly/1713566/dotnet451itrpck Japanese: http://adf.ly/1713566/dotnet451jarpck Korean: http://adf.ly/1713566/dotnet451korpck Norwegian (Bokmal): http://adf.ly/1713566/dotnet451norpck Polish: http://adf.ly/1713566/dotnet451plrpck Portuguese (Brazil): http://adf.ly/1713566/dotnet451ptbrpck Portuguese (Portugal): http://adf.ly/1713566/dotnet451ptgrpck Russian: http://adf.ly/1713566/dotnet451rurpck Spanish: http://adf.ly/1713566/dotnet451esrpck Swedish: http://adf.ly/1713566/dotnet451svrpck Turkish: http://adf.ly/1713566/dotnet451trrpck Changelog: 9-19-2014 Add: 2972216 Hotfix list: Full: 2972216 FullLP: NONE HJSC, jimmsta, Ond3rkor and 5 others 8 Quote
ricktendo Posted November 26, 2012 Author Posted November 26, 2012 HechoP.D. vuelvan a descargarlo, acabo de recrear un nuevo paquete con cambios menores a los MSI Quote
Dziubek Posted November 27, 2012 Posted November 27, 2012 For the polish language please rickthank you for your work so far and feedback Quote
tr011_tmn Posted November 27, 2012 Posted November 27, 2012 For the Russian language please RickThank you in advance for your work and your time. :prop: Quote
parapher Posted November 27, 2012 Posted November 27, 2012 Rick, how is this better than the *Slim* installer you've been updating as well? Also, what are the switches, if any, that can be used on this installer, and can we now decide to install client and/or extended? Quote
ricktendo Posted November 27, 2012 Author Posted November 27, 2012 No you cannot install client only, the switches are the same as the default setup (run installer with /?) and I dont think its better but it uses the original setup files, proprietary self extractor a.k.a. sfx (vs general 7zip sfx) and nothing is removedI may switch over the Slim installer to use the original setup/sfx, will still be slim and will still not copy any setup junkImportant: Next update to this installer will be 90MB+ in size. Its because of the compression method of the cab a.k.a. netfx_Full.mzz:The original cab/mzz is 202MB (unknown compression method,) the one in this installer is 446MB (no compression,) but I can compress it down to about 90MB (smallest/best compression method lzx:21) that will save you over 100MB of disk space vs the original and nearly 350MB vs the current installerI think its better to have a small install footprint vs a normal sized installer. This way no matter what installer you use (slim or rebuilt) you will still save plenty of space on your HDD/SSD Quote
parapher Posted November 28, 2012 Posted November 28, 2012 Thanks for the information, Rick.I may switch over the Slim installer to use the original setup/sfx, will still be slim and will still not copy any setup junkBut this will not make it bigger than the Slim installers are now? Quote
HJSC Posted November 29, 2012 Posted November 29, 2012 Nice work, Rick =)You could add PTB (portuguese brazilian) language? Thanks ^^ Quote
George King Posted November 29, 2012 Posted November 29, 2012 Hi Rick, can you please make cs-CZ language pack? Quote
ricktendo Posted December 12, 2012 Author Posted December 12, 2012 12-12-2012Add: 2783808Rem: 2745582Important: Better compressed the MZZ/CAB file with LZX:21, saves 108 MB of disk space over original and 321 MB over the previous rebuilt installer (the only side effect is a larger installer) Quote
Balbis Posted December 13, 2012 Posted December 13, 2012 Rick cual es mejor este pack o el slim? Gracias! Quote
ricktendo Posted December 13, 2012 Author Posted December 13, 2012 Depende de lo que quieres. Use este instalador si quieres seguir siendo fiel al instalador original de Microsoft, o use el slim si no quieres archivos innecesarios en tu disco duro (los dos instaladores contienen las mismas actualizaciones)Ahorras +o- 200 MB de espacio con el slim (porque el instalador ha sido editado para eliminar el gui/setup y dejar solo los archivos .net45) y con este ahorras 108 MB (porque se ha comprimido mejor el dotnet_Full.mzz) geodasoft 1 Quote
ricktendo Posted January 8, 2013 Author Posted January 8, 2013 1-08-2013Add: 2742613, 2750147Rem: 2748645, 2759112, 2777291, 2783808 Quote
ianymaty Posted January 11, 2013 Posted January 11, 2013 Hi Rick, can you add Romanian ro-RO LP, please?Thanks. Quote
ricktendo Posted January 11, 2013 Author Posted January 11, 2013 I would if that LP existed (I cant find it) Quote
ianymaty Posted January 11, 2013 Posted January 11, 2013 Since the LP for Windows 7 exists, I thought there is an LP for .NET too, just like for IE9. You are right, there isn't. I'll use the english version than. Thanks. Quote
Kelsenellenelvian Posted January 11, 2013 Posted January 11, 2013 rick = I really am glad I balked at your suggestion of adfly. Personally what the toolkit and your addons do is just not well right. I know that there are only a few people that actually support our work but to make everyone jump through these hoops is really microsofty. I have been trying to dl your 4.5 slim for 2 days now and still can't get it. I REALLY don't like when I am bombarded with porn for a tech link either.Also please don't just give me a direct link it's not fair to the other actually decent people here. It's like the adfly in the toolkit for links to ms sites and products. Is that even legal? Quote
