Posted (edited)
Prio - Process Priority Saver, by O&K Software
Download: NR_Prio1.98_Addon.rar
MD5: 6A1CA110CD187B4F54B9968CF75ED6DB
Website: http://www.prnwatch.com/prio.html
A little information from website:
Have you ever changed the priority of a process in the Task Manager?
Do you have to do it often?
Do you want your database server or media player to know the priority it should work with?
This compact program allows you to save the priority you specify for any process.
How to use:
  • Start the Task Manager.
  • Right-click a process and select Set Priority.
  • Set the priority you want for the process.
Prio will save the applied changes and each time you start this process from now on, it will set the saved priority for it. You will not have to change the priority manually any more.
For more info, please check Website.
NOTES: FGCBA didn't find any errors. Tell me if you find. Fully uninstallable.
Program uses "%userprofile%\Application Data\prio.ini" file to save settings. If you delete it, you will lose all your settings.
Changelog:
2008-02-04: Updated to 1.9.8
Edited by MrNxDmX
  • 3 months later...
This is a nice application. And for this app I need a add-on because I've to restart my PC with a normal installer. But the installer is outdated (v1.97 is out).
Can you update?
Thanks. :thumb_yello:
  • 4 months later...
  • 1 year later...
  • 1 year later...
Posted (edited)
here is Prio 1.99 main link
http://prnwatch.com/prio.html
I checked it only tool tip appear in task manager there was no change except.
I am afraid to set priority before knowing which should be high.
can Any body tell which should prefer high.Site show a large shell menu.
Edited by J.S.Prasad
