Gorki Posted June 9, 2007 Posted June 9, 2007 (edited) Stress Prime 2004 Orthos v0.41.110.18SP2004 uses a redesigned user interface that calls Version 23 Prime95's torture test code. This should provide the same results as Prime95, just displayed in a different manner.SP2004 provides: * Easily-visible test status. SP2004 displays the current status of the app in a large font on an appropriate background colour. When an error occurs during the test, SP2004 will also: o flash the dialog window o play a sound named fail.wav or a beep if a WAV file of that name doesn't exist o flash the scroll lock key LED o change the app icon from a 'dormant volcano on a sunny day' to an 'erupting volcano on an overcast day' o SP2004's tray icon displays a tooltip window that shows the current test status * Time-related test status. SP2004 displays the test start time and how much time has elapsed. * Log window text that can be copied.Download: MD5: 10E1CA098BCF463A510C611E026FA375Size: 443KBChangelog:23-June-07v0.2- added Add/Remove entries in Control Panel- relocated program shortcut to All Programs/Utilities/...9-June-07v0.1- initial release- no add/remove entries Edited June 22, 2007 by Gorki Quote
Gorki Posted June 22, 2007 Author Posted June 22, 2007 Updated first post... Credit goes to ricktendo64 :mario: :thumbsup: Quote
ricktendo Posted June 23, 2007 Posted June 23, 2007 This is now a true addon so moved from svcpack to here Quote
Huh? Posted August 24, 2007 Posted August 24, 2007 Thanks Gorki and ricktendo64! :thumbsup_anim: I miss playing my N64 and all Mario games.... That was a long time ago.... Quote
