MrNxDmX Posted June 22, 2007 Posted June 22, 2007 (edited) This addon will install "SCSI Pass Through Direct Drivers" at t13 stage of windows install. You will be able to install daemon tools (or programs requiring SPTD) without re-starting your system. This addon will not restart your computer during windows installation.***Not yet tested on a live system. I did this 7zip switchless with "add /q" switch. Please report back after testing.*** or 1D8376F0321B265623A2018C7B887056 810 KB Edited April 17, 2008 by MrNxDmX Temp. updated v1.55 by ricktendo64 Quote
Helmi Posted June 22, 2007 Posted June 22, 2007 If I'm already using a DT AddOn with an older version of this, do I integrate this before or afterwards?Also, using nLite to slipstream my AddOns, how do I tell it this (not manually editing the answering files, if possible)?That said, if this is too complicated, could I ask you to create a full pack using the latest DT in conjunction with this SPTD? Quote
bober Posted June 22, 2007 Posted June 22, 2007 always make it so the stpd drivers are installed b4 the app that uses it. Quote
MrNxDmX Posted June 23, 2007 Author Posted June 23, 2007 (edited) bober is right. This must be installed before the app needs this. Also, if you want to install DT, you need to restart your computer after installing this program. RogueSpear has an addon that installs both with one addon, but it's too complicated for me. Check it out here. Edited June 23, 2007 by MrNxDmX Quote
Mr.McNally Posted July 1, 2007 Posted July 1, 2007 always make it so the stpd drivers are installed b4 the app that uses it. Perhaps that is why I got this error? Unfortunately for me I have no idea what "framedyn.dll" is?! Quote
ricktendo Posted July 1, 2007 Posted July 1, 2007 "framedyn.dll" error will happen if you have a bad INF addon... Quote
MrNxDmX Posted July 1, 2007 Author Posted July 1, 2007 Did that windows installed correctly? If no, there's sth wrong with your disc. please try doing the integration again. Quote
Mr.McNally Posted July 2, 2007 Posted July 2, 2007 Did that windows installed correctly? If no, there's sth wrong with your disc. please try doing the integration again. No it didn't install correctly. I have been making my installs from a XP pro SP2 image file I made that I keep mounted in a virtual drive. I have made good installs in the past with it, but lately I have been having problems. I posted this error here because the error message box was named SPTDinst. I assumed that the error was the fault of the SPTDrivers I was trying to install, of which I have no experience using. It is highly likely that the error is elsewhere if others are using this addon successfully. In fact, since I left this post I cut out any of the addons that I thought I might not need upon first startup and the problem is gone. I didn't reinstall the SPTD though. I don't know enough about what they do and I have Alcohol 120% so I don't usually install Daemon tools. I thought it would be nice to have virtual drive setup at first boot, but I realized today that Kel's Uber pack, which I have also been integrating, already has MS virtual drive. Rick is probably right because I have been getting an error message during the first few minutes of the installation which says "Setup can not copy FolderC.inf" and I am given the option to ignore, try again or quit. The error message happens just after setup formats the partition and begins to copy files. I used the "skip" option a couple of times, and this may be the result. Its funny but I can search the pre-iso installation files and I can not locate this FolderC.inf file anywhere, although this may be the problem that setup is complaining of. ? :doh: I must admit that it is very hard to remedy the setup complaints when I dont understand what setup is complaining about! Thanks for your help, I will come to understand this stuff sooner or later. Quote
Mr.McNally Posted July 4, 2007 Posted July 4, 2007 I have isolated my FolderC.INF error and it has nothing to do with the SPTDs. Sorry if I caused any alarm or confusion. :doh: :welcome: Quote
Mr.McNally Posted August 26, 2007 Posted August 26, 2007 It has been a while since I last posted regarding this addon. I just wanted to say that it work flawlessly for me. What ever sort of issue I was having before had nothing to do with this addon. I wanted to offer that explanation so as to not deter anyone from using your most excellent addon. Great work as always, MrNxDmX :welcome: Quote
ricktendo Posted January 18, 2008 Posted January 18, 2008 updated for the time being by moi v1.55 Quote
grzegorzo Posted January 18, 2008 Posted January 18, 2008 Thank you rick ! ! ! ! you are the best ,standing ovation :worthy: Quote
ALEN Posted April 5, 2008 Posted April 5, 2008 (edited) SPTD 1.56http://rapidshare.com/files/100933260/SPTv156_Addon_ALEN.cabMD5 => 272C8047252D2BCAF24F40336F06ADB8Size => 766 KB (785.283 bayt) Edited April 5, 2008 by ALEN Quote
MrNxDmX Posted April 17, 2008 Author Posted April 17, 2008 Thanks Alen. First post is updated with v1.56 release.@ Rick: Can you remove that "edit" tag from first post Thanks for updating this when i was offline Quote
