Posted June 22, 200717 yr Driver Genius Professional Edition 2007 v7.1.0.662Info: Driver Genius is a powerful driver manager for Windows that can backup, restore and update your drivers in several mouse clicks!MD5: 7C280D20C29F3B46FADDE1A63791C49ESize: 7.70 MBWebsite: http://www.driver-soft.com/Registration Instructions:To add your Register.key and Updated Drivers.dat files.- Uncomress addon and DrvGen.CAB archive located inside addon both to sub-folders- Install the program and register as you would do normally- Browse to %ProgramFiles%\Driver-Soft\DriverGenius and copy Register.Key and the updated Drivers.dat (optional driver database) into extracted DrvGen sub-folder and repack it to cab- ZIP, RAR, CAB or 7-Zip the addon as it was before and integrate...
June 22, 200717 yr Hey, what's an easy way to recompress the CAB?I suppose makecab would work, however, I wouldn't mind if it was somehow possible to add that feature to 7-Zip (which can by default only uncab, not recab :/).EDIT:Ok, and if I'm using makecab, how do I tell it to use all files in the current dir?Wildcards (*.* / *) do not work... Edited June 22, 200717 yr by Helmi
June 22, 200717 yr Author I use TUGZip but if you have CabTool you can right click on a folder and send to Cabtool and it will make a CAB file with the same name as the folder
