Posted (edited)
XML Notepad 2007 provides a simple intuitive user interface for browsing and editing XML documents.
This program is very useful and free solution because the old Word 2000 is the only program you can edit the "*.xml" files. Internet Explorer only allows you to view the files, and notepad and wordpad will save the .xml as a text file.
Direct 'Double-click' and native 'Right-click' open support for XML:
XML Notepad: window
Download 32-bit
Size=819 KB | SHA1: dc955e787f1e753b8831bc99ceb8be0948b70cc1
Download 64-bit
Size=819 KB | SHA1: e627b7f71cd44a0d772555b54d6f80241612a5c2
Homepage
Edited by MAXtoriX
