Kelsenellenelvian Posted June 25, 2007 Posted June 25, 2007 AttentionI decided to remove the MS runtimes from this pack!I did so because Yumeyao has and mantains a VERY excellent Microsoft Runtime Libraries Collection(x86)Link = http://www.ryanvm.ne...opic.php?t=8563Plus onepiece has some of the others built into his pack!This is a collection of dll's that alot of programs need to run smoothly. Use this pack to avoid the This program needs blah.dll to run prompts. (especially if you use a lot of freeware or portable apps)Change log:cgwin1.dll 1007.9.0.0libeay32.dll 1.0.0.5libssl32.dll 1.0.0.5 ssleay32.dll 1.0.0.5Partial List Of Included Runtimes.Auto-itLoads of various runtimes you might need for ANY portable legacy appOpenalVista SP2 USP10.dll for greater unicode support. (Can't add the Win7 one)Full List of runtimes included...Name Version autoitx3.dll 3.3.6.1 cygwin1.dll 1007.9.0.0 libeay32.dll 1.0.0.5libiconv2.dll 1.9.2.1519 libintl3.dll 0.14.1.1737 libmmd.dll 10.1.10.2 libpng13.dll 1.2.31.0 libssl32.dll 1.0.0.5 msstdfmt.dll 6.1.98.16 msstkprp.dll 6.1.98.16 openal32.dll 6.14.357.24 plugin.dll 3.0.64.101 ssleay32.dll 1.0.0.5 usp10.dll 1.626.6002.22384wrap_oal.dll 2.2.0.5 zlib1.dll 1.2.5.0 comct232.ocx 6.0.98.16 comct332.ocx 6.7.0.9816 comctl32.ocx 6.0.98.16 comdlg32.ocx 6.1.98.16 dblist32.ocx 6.1.98.16 mci32.ocx 6.1.98.16 mscomct2.ocx 6.1.98.16 mscomctl.ocx 6.1.98.18 mscomctl32.ocx 6.0.88.62 mscomm32.ocx 6.1.98.16 msdatgrd.ocx 6.1.98.16 msdatlst.ocx 6.1.98.16 msflxgrd.ocx 6.1.98.14 mshflxgd.ocx 6.1.98.16 msinet.ocx 6.1.98.16 msmask32.ocx 6.1.98.16 mswinsck.ocx 6.1.98.17 picclp32.ocx 6.1.98.16 richtx32.ocx 6.1.98.16 sysinfo.ocx 6.1.98.16 tabctl32.ocx 6.1.98.16http://www.wpiw.net/...ddon_v7.8.4.rarSize - 5.04 megsFile: Kels_Runtimes_addon_v7.8.4.rarCRC-32: e395701cMD4: 2b0c8160b114612bc24b16a99f865eacMD5: e71d32a6737e42b63a2e6c8372dab678SHA-1: 5cc859716c75a80704e242b1d0197dc3e5ba3545 JCM and NECRONEMESIS 2 Quote
ricktendo Posted June 25, 2007 Posted June 25, 2007 YAY! awesome Kel, bring all of your addons over. Quote
Kelsenellenelvian Posted June 25, 2007 Author Posted June 25, 2007 ALL 143 OF THEM?????That might take some time Quote
Inferi0r Posted September 12, 2007 Posted September 12, 2007 (edited) Can you add cygwin1.dll (I had v1005.24.0.0)?It's more known/ used then cygwin19.dll which one also is added.Edit: Thanks for the fast reply. Edited September 12, 2007 by Inferi0r Quote
xms3500 Posted October 28, 2007 Posted October 28, 2007 Thanks for the update Kel. :thumbsup_anim: Quote
yadzil Posted December 9, 2007 Posted December 9, 2007 Does your addon include visual basic c++ 2005 sp1? Quote
yadzil Posted December 10, 2007 Posted December 10, 2007 but I having problem while installing Nero 8. msg said that need of Microsoft Visual C++ 2005 SP1 appear. Quote
Kelsenellenelvian Posted December 10, 2007 Author Posted December 10, 2007 http://www.microsoft.com/downloads/details...;displaylang=enWhat language are you using (Of both windows AND nero) Becuase the asms\80 folder is that series of runtimes. Quote
Beetsie Posted December 10, 2007 Posted December 10, 2007 You might wanna add a description just so people know what these are and exactly what they do? Quote
Kelsenellenelvian Posted December 10, 2007 Author Posted December 10, 2007 HAhahahahahahah I don't know really how to describe them.They are ummmm RUNTIMES! Yeah thats it. It is a collection of dll's that alot of programs need to run smootly. Use this pack to avoid the "This program needs blah.dll to run" prompts. Quote
Kelsenellenelvian Posted December 10, 2007 Author Posted December 10, 2007 RuntimeFrom Wikipedia, the free encyclopediaIn computer science, runtime or run time describes the operation of a computer program, the duration of its execution, from beginning to termination (compare compile time). The term runtime can also refer to a runtime library, a program or library of basic code that is used by a particular compiler or virtual machine to manage a program written in a computer language while it is running.A runtime environment is a virtual machine state which provides software services for processes or programs while a computer is running. It may pertain to the operating system itself, or the software that runs beneath it. Quote
yadzil Posted December 11, 2007 Posted December 11, 2007 http://www.microsoft.com/downloads/details...;displaylang=enWhat language are you using (Of both windows AND nero) Becuase the asms\80 folder is that series of runtimes.I use both windows and nero english version. I'll try to reinstall it back and inform you the result.Thanks Quote
