TransBar v1.4.2 by AKSoftware
Info: Transbar is a little tweaking tool which takes advantage of Alpha Transparency in Windows 2000, Windows XP and Vista. Using TransBar, you can adjust the transparency level of your taskbar meaning that a full screen wallpaper is made partially visible through the taskbar.
MD5: B595672B73097A6C86029B71082B2194
Website: http://www.aksoftware.tk/
  • 4 weeks later...
I know, but it says cant find the .inf.
You have to copy .inf file from addon to your WINDOWS/inf directory (make shure you have enabled show hiden files and folders option othervise you wont' see inf folder under windows) ... good luck.
hi
can you please update your addon to make it startup on first boot up please. or is there any way i can edit the inf file to make it start up on first boot
thanks
Posted (edited)
How I can get transbar program with the fixed opacity %87
I want it like this after I setup my xp
help me rick please :thumbsup_anim:
Edited by ss_tekin
I'm glad that I have BricoPack Vista Inspirat Ultimate 2 installed :thumb_yello:
In this package you'll find everything what's new like Transbar, YzShadow, UberIcon, ResHacker, RocketDock. Brickopack sets everything I just configure it to my settings and set's it :whistle:
Getting me always the new addons to be up to date and here @ WinCert.net you get the best addons :whistle:
i have bricopack vista 2 how do you configure the transbar i click on it but there is no pop up to configure it!!!??
Posted (edited)
Try lookin here C:\WINDOWS\BricoPacks\Vista Inspirat 2\TransBar then click on the .exe ;) if u want move the short cut to the desktop
Edited by wrx
