Kelsenellenelvian Posted July 2, 2007 Posted July 2, 2007 Tweak UIThis PowerToy gives you access to system settings that are not exposed in the Windows XP default user interface, including mouse settings, Explorer settings, taskbar settings, and more.Version 2.10 requires Windows XP Service Pack 1 or Windows Server 2003.Simply put this addon adds TweakUI into your control panelDownload here!Size - 87.6 kb MD5Hash = 57415968A16ECC1AF87616B34D98FEA6 Quote
khan Posted December 28, 2008 Posted December 28, 2008 Link is Dead. Please reupload this addon. Tweakui has options to disable autoplay USB /Other drives. Quote
khan Posted December 28, 2008 Posted December 28, 2008 You are super quick... :giveheart: Thanks. :thumbsup_anim: Quote
Humfri Posted March 3, 2012 Posted March 3, 2012 Hi,btw thanks for all your addons!I found that this one doens't actually copies the tweakui.exe into the system32 directory. I'm not a pro, but i figured the .inf file should be like this, unless there's something I didn'T get:[Version]Signature="$Windows NT$"[Defaultinstall]OptionDesc ="Adds TweakUI to the control panel"Tip ="TweakUI"Modes =0,1,2,3AddReg =Tweak.reg[b]copyfiles =prog.copy[/b][Optional Components]TweakUI[TweakUI]OptionDesc ="Adds TweakUI to the control panel"Tip ="TweakUI"Modes =0,1,2,3AddReg =Tweak.reg[b][DestinationDirs]Prog.Copy = 11[/b][b][sourcedisksfiles]TweakUI.exe =1[/b][b][Prog.Copy]TweakUI.exe[/b][Tweak.reg]HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}",,,"TweakUI"HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}","InfoTip",,"TweakUI customizes many advanced options in Windows"HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}\DefaultIcon",,,"%SystemRoot%\\System32\\tweakui.exe,0"HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}\Shell\Open"HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}\Shell\Open\command",,,"tweakui.exe"HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}\ShellFolder","Attributes",0x00010001,30,00,00,00HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{D14ED2E1-C75B-443c-BD7C-FC03B2F08C17}",,,"Add Tweakui to Control Panel"TweakUI.inf.txt Quote
Kelsenellenelvian Posted March 3, 2012 Author Posted March 3, 2012 You are ENTIRELY wrong..This addon uses an advanced methos to add TweakUI to the dir!IN the entries file. [dosnet_files]d1,TweakUI.EXEd1,TweakUI.inf[txtsetup_files]TweakUI.EXE = 1,,,,,,,2,0,0TweakUI.inf = 1,,,,,,,20,0,0Thus adding the file(s) into the ACTUAL base XP install routine... Quote
