Posted (edited)
Y'z Shadow v1.9
Author :: M.Yamaguchi
Y'z Shadow adds a shadow effect to the windows in pursuit of the "beauty of a shadow".
It also allows the user the option of making menus transparent.
Features
* Attaches a drop shadow to the windows.
* Makes it possible to select one type of shadow effect in the active window and a different one in the inactive window.
* The user can choose to have transparent menus. There is also the option of selecting the degree of transparency in the menus.
* Add a drop shadow to the menus.
* Add a drop shadow to the taskbar.
* The width, depth, etc. of the drop shadows can all be set to your liking in the settings dialog.
* It works correctly with either WindowsXP styles or classic style.
* The user can specify application windows that you wish to exclude from having the drop shadow effect.
* The user can choose a setting that will automatically adjust your windows so they do not overlap or interfere with the taskbar.
* Available in different languages (Japanese and English).
Download: Gorki_AddOn_Y__z_Shadow_1.1.cab
MD5: A47912D75B982F5809270FD4F55EF858
Destination dir: Start Menu/All Programs/Utilities
Note: Startup entry included by default, improved uninstall entries so no leftovers are left behind (thx Rickendo64 )
Changelog:
27-July-07
v1.1
- english language set as default
v1.0
- first release
Edited by Gorki
If you are going to have it startup on 1st login you might want to set the lang and include YzShadow.ini settings file so you don't get the "Select Language" popup
