Posted August 1, 200717 yr HashTabHashTab is a Windows shell extension which adds a tab called "File Hashes" to the Windows Explorer file properties. The tab contains the MD5, SHA1 and CRC-32 file hashes. These are common hashes that are used to verify the integrity and authenticity of files. Many download sites list the MD5 hash along with the download link. The HashTab makes it very simple for Windows users to check these hashes on any file on the system without using external tools. The screenshot to the right shows an example. @210KB eaba8212fe140bd6ac6e5fd83ad2bb5fNote: (non uninstallable) , MD5 setting enabled by defaultChangelog:15-February-09 - Updated to version 2.3.0 08-September-08 - Updated to version 2.1.117-June-08 - Updated to version 2.1.025-May-08 - Updated to version 2.0.9 25-December-07 - Updated to version 2.0.815-December-07 - Updated to version 2.0.728-November-07 - Updated to version 2.0.522-November-07 - Updated to version 2.0.418-November-07 - Updated to version 2.0.315-August-07 -updated to new version 1-August-07 -initial release Edited March 11, 200916 yr by Gorki
August 1, 200717 yr Thanks mate. Can you make no-uninstallable version?I like my Add/Remove programs stay clean.
August 1, 200717 yr Author Thanks mate. Can you make no-uninstallable version?I like my Add/Remove programs stay clean.Up you go :lol:
November 21, 200717 yr Just a heads-up, but version 2.0.4 has already been released (that was kinda fast, coming from 2.0 ).[11/18/2007] 2.0.4 hotfix released A hotfix for the 2.0 release is available here. This hotfix contains the following changes: Fixed hash settings listbox layout Fixed spelling error on the main dialog Fixed a problem when cancelling and resuming hashing on large files Added Greek, Italian, Russian and Japanese UI translation Fixed a bug when trying to hash an external file for comparison Fixed the reset button in the hash settings dialog Fixed a potential deadlock when closing the dialog during a hash operation Fixed a problem where the hashes were being recalculated if you press enter in the compare text box Fixed a problem with the installer on 64-bit windows where the Add/Remove programs entry was not being removed correctly
December 25, 200717 yr Author Thanks for info kiki burgh. seams like link was down..I upload it again to another source. It works now.
February 18, 200817 yr when i used this, i went into the hash tab and there was no "hashs" selected to display. So I had to right-click, goto settings, and check which ones to display. Anyway to have them displayed by default?
February 19, 200817 yr when i used this, i went into the hash tab and there was no "hashs" selected to display. So I had to right-click, goto settings, and check which ones to display. Anyway to have them displayed by default?In my personal addon, i have a HashTab.AddReg section in the inf... (Learned it from Xable) [HashTab.AddReg]HKCU,"Software\HashTab\Algorithms\MD5","Enabled",0x10001,1HKCU,"Software\HashTab\Algorithms\SHA-1","Enabled",0x10001,1HKCU,"Software\HashTab\Algorithms\CRC32","Enabled",0x10001,1These are the 3 I choose to have shown by default...... You can have just one or ALL...Its up to you.....
March 21, 200817 yr Hey mate, your download button gives a 404 error, so your link isnt shown.I found the link, though, http://www.mediafire.com/?8ntd4pxzidm
March 21, 200817 yr Author Yes MrNxDmX,thanks for info. I forget to update dl link since wincert had some problems before with codes. Thanks for letting me know.
May 27, 200816 yr I was just looking for something similar to this about a week ago...Looks like I've finally found it.Thanks!
