Gorki Posted August 2, 2007 Posted August 2, 2007 (edited) JkDefrag GUI Description: JkDefrag GUI is a graphical user interface program for the open source hard drive defragmentation program JkDefrag. It enables users to easily use JkDefrag Edited October 20, 2008 by Gorki Quote
ScOOt3r Posted August 20, 2007 Posted August 20, 2007 sweet, thanks Gorki, this will come in handy. ThanksScOOt3r Quote
Ton80 Posted September 12, 2007 Posted September 12, 2007 http://www.emro.nl/freeware/has been updated to .92 Quote
Gorki Posted October 26, 2007 Author Posted October 26, 2007 Updated...Sorry guys took me a long time to noticed that someone still needs this app. Quote
iuli_kyle Posted December 1, 2007 Posted December 1, 2007 it would be nice if we would have a CPL addon too Quote
Gorki Posted December 1, 2007 Author Posted December 1, 2007 JkDefragGUI 1.0 released. Thanks. :icon_cool: it would be nice if we would have a CPL addon too ummm... you where saying... Enjoy! And for the record..this is my first addon with CPL shortcut Quote
theSLug Posted February 26, 2008 Posted February 26, 2008 (edited) JkDefragGUI 1.01 31 january 2008 Changes:- Added Automatic update of the scheduled job with newest jkdefrag when downloaded- Added Automatic update of the installed version with newest jkdefrag when downloaded- Added Croatian translation- Added Indonesian translation- Added option to add a delay when doing a schedule at logon- Added option to show logfile after defragmentation (GUI only)- Added empty Prefetch folder to Internal Cleaner- Added pagedefrag to the U3 version of JkDefragGUI- Added JkDefrag history to menu- Fixed helpfile not displayed on network drive- Fixed bug JkDefrag version not updated when updated through automatic update at startup- Fixed bug JkDefrag downloaded everytime when run from BartPe enviroment- Fixed bug "Show System" selected on startup when disabled- Fixed bug spacehogs disabled when selected and enabled when not selected- Fixed bug calendar not displayed correctly on Vista OS- Improved U3 version no need re-download JkDefrag on every usage- Removed screensaver copied to system32 during update when not installed- Removed some external links in help menu from BartPE Mode Edited February 26, 2008 by theSLug Quote
Gorki Posted March 4, 2008 Author Posted March 4, 2008 Wincert.net had some ishues with uploading code so they had to be removed. It's fine now,I also updated my addon. Quote
spidernz Posted March 10, 2008 Posted March 10, 2008 so i have to dl jkdefrag separate or does it come with this? Quote
JBrinley Posted March 25, 2008 Posted March 25, 2008 anyway for this to replace the windows defrag? So when i click defrag in disk properties, it will load this app? Quote
Gorki Posted March 25, 2008 Author Posted March 25, 2008 so i have to dl jkdefrag separate or does it come with this?anyway for this to replace the windows defrag? So when i click defrag in disk properties, it will load this app?This app is standalone utility and it has all entries and files included to operate normal so you dont' have to download any file. And it does not replace standard derag application. Quote
theSLug Posted May 30, 2008 Posted May 30, 2008 JkDefragGUI 1.02 May 8th 2008 Changes:- Added automatic detection of indonesian language at first start of JkDefragGUI- Added disk washing, replace erased information with garbage- Added color help to tray menu- Fixed bug CCleaner only executed when internal cleaner is selected before CCleaner- Fixed bug LogFileAfterDefrag setting not set in the GUI after restart- Fixed colors green switched in JkDefrag color help- Fixed bug Serbian language not selected in language menu- Fixed keylogger detection by some firewall applications- Made GUI Smaller when in BartPe Mode- Reduced and improved code- Removed external help files from GUI to reduce size of GUI executable- Replaced external program wait.exe with selfmade one- Some typo corrections in multiple language files Quote
Happy-Dude Posted October 15, 2008 Posted October 15, 2008 New version released !!JKDefrag GUI 1.03Changes:- Added JkDefrag.exe and other files to the archive, request of Jeroen Kessels- Added a question to download JkDefrag when it isn't found in the program folder otherwise quit- Added check to see if CCleaner is installed on local computer and update JkDefragGUI with this version- Added Ukrainian translation- Added Turkish translation- Added /s to commandline this will autoselect "Shutdown after defrag" in the GUI- Added /r to commandline this will automaticly run JkDefrag with saved options- Added /rs to commandline this will automaticly run JkDefrag with saved options and shutdown afterwards- Changed location of logfile when saved in the same folder as the GUI for U3 Devices to U3 Documents- Created a new icon for JkDefragGUI- Embedded background image into the executable- Fixed bug Installer not working 100% when JkDefragGUI.exe is renamed- Improved internal cleaner reading settings from all existing profiles- Improved support CCleaner, internal cleaner can control CCleaner settings- Improved deleting folders IECache and History current user, will not leave empty folders anymore- JkDefragGUI not packed with UPX anymore to reduce the amount of false positives by virusscanning software- Logfiles are saved with date and time in name and can be read from within the GUI- Logfiles can be deleted from within the GUI- Updated Uninstaller, a registry value was left behindhttp://www.emro.nl/freeware/ Quote
