Kelsenellenelvian Posted August 5, 2007 Posted August 5, 2007 Ok here is a combo addon of the good old cmd Promt Here regtweak and the BackGround cmd prompt here shell extension!Website = http://www.ktechcomputing.com/cmdopen/This will in essence give you the ability to open a command prompt from any folder or even inside the folder (Even the desktop)Size - 7.66 kb MD5Hash = B269AB6013737EB43635938DF3A10158And yes this is in my uber-pack!!! AntarV 1 Quote
qwesta Posted July 1, 2008 Posted July 1, 2008 is it possible to have this install from *.info other than intergration?thank you Quote
Kelsenellenelvian Posted July 2, 2008 Author Posted July 2, 2008 Not right now but give me like 15 minutes and it will be.... Quote
Kelsenellenelvian Posted July 2, 2008 Author Posted July 2, 2008 OK fully updated to a cmd anywhere .dll!Yes now you can extract it and right click, install now... Quote
gauntletxg Posted July 8, 2008 Posted July 8, 2008 thanksi had no problems with the first release, but the latest one seems to be breaking something.im using xp sp3 and nlite 1.4.7 with no other addons/modifications other than this oneany ideas? Quote
Kelsenellenelvian Posted July 8, 2008 Author Posted July 8, 2008 Yup its fubared and I see where I went wrong I will fix in a few minutes Quote
