Kelsenellenelvian Posted August 5, 2007 Posted August 5, 2007 This tiny little app does several things!First it Compresses the drivers from your selected location keeping ONLY the needed driver files (NO extra crap bloat)I usually get a savings of 55% or more in space.This saves tons of needed space on your Windows setup CD's or even just a driver CD----------------------------------Changelog:----------------------------------2007.08.09 Added XP installation CD driver integration.2007.08.03 Renamed next button into Start.2007.08.03 Fixed cancel button so the program exits.2007.07.19 Fixed compatibility with Win98 as host OS.2007.07.17 Added nVidia international driver support2007.05.19 Improved check for source and destination dir.2007.05.17 Added about link to readme.txt.2007.05.17 Added some debug info to the log file.2007.05.17 Fixed error 'Parameter format not correct'.2007.05.16 Added check for same source and destination dir.2007.05.16 Added displaying version.2007.05.16 Copy catalog is selected by default.2006.03.07 Disabled warning message for missing .com, .sys, .dos and .vxd files.2006.03.06 Fixed error with files extensions less than 3 characters (ATI).Can add the drivers to a XP cd after compression!Size - 91.7 kb MD5Hash = 4364CB0C19BE878B71D28CEB4D6F6663 Quote
ricktendo Posted August 9, 2007 Posted August 9, 2007 2007.08.09 Added XP installation CD driver integration.Cool gonna give it a go Quote
madata Posted November 16, 2007 Posted November 16, 2007 What I would Love Is To See This To Be Able To Scan The Windows XP Disc & Copy Out All Of The Drivers Into A Backup Folder, Using the same compression Technique & Then Be Able To Use Nlite To Remove All The Drivers & Reload The Compressed Drivers Version. Thereby The XP Drivers Are Still Loadable But Not Taking As Much Room.Thnnx Madata Quote
JurgenDoe Posted November 18, 2007 Posted November 18, 2007 got to give it a try...sounds really need :icon_cool: Quote
Guest Posted February 1, 2009 Posted February 1, 2009 This tiny little app does several things!First it Compresses the drivers from your selected location keeping ONLY the needed driver files (NO extra crap bloat)I usually get a savings of 55% or more in space.This saves tons of needed space on your Windows setup CD's or even just a driver CD----------------------------------Changelog:----------------------------------2007.08.09 Added XP installation CD driver integration.2007.08.03 Renamed next button into Start.2007.08.03 Fixed cancel button so the program exits.2007.07.19 Fixed compatibility with Win98 as host OS.2007.07.17 Added nVidia international driver support2007.05.19 Improved check for source and destination dir.2007.05.17 Added about link to readme.txt.2007.05.17 Added some debug info to the log file.2007.05.17 Fixed error 'Parameter format not correct'.2007.05.16 Added check for same source and destination dir.2007.05.16 Added displaying version.2007.05.16 Copy catalog is selected by default.2006.03.07 Disabled warning message for missing .com, .sys, .dos and .vxd files.2006.03.06 Fixed error with files extensions less than 3 characters (ATI).Can add the drivers to a XP cd after compression!Size - 91.7 kb MD5Hash = 4364CB0C19BE878B71D28CEB4D6F6663hi kel im wating for youlink dosent work Quote
