Posted August 13, 200717 yr OK I'm starting this so people with/without Vista/Server 2008 can post/request resources/programs for VAIO and Alky for ApplicationsAlky List of supported files: http://www.fallingleafsystems.com/site_media/matrix.htmlWindows Vista RTM Sidebar v6.0.6000.16386Windows Server 2008 Sidebar v6.0.6001.16510Texas HoldemHotfix Extractor (drag and drop holdem hotfix into it): HFExtract_ENG.rarVista RTM Programs: RTM_Programs.7zFeel free to post/request
August 13, 200717 yr Thanks Rick...if I have a request for some gadget I'll come back :icon_rolleyes:
August 13, 200717 yr so...exactly how would i go about installing texas hold 'em or making an addon out of it? i used HFExtract but dont know where to go from there...
August 14, 200717 yr Author so...exactly how would i go about installing texas hold 'em or making an addon out of it? i used HFExtract but dont know where to go from there...For instructions type this in Run box"%ProgramFiles%\Alky for Applications\Documentation\manual.pdf"You also need to install Alky with a Premium Vista KeyYou can download XInput9_1_0.dll & patch with alky and add it to the same dir as Texas Holdem (you can find it in RTM Programs)This is how the texas holdem patched with alky dir should finally look likeen-US\holdem.exe.mui <-make sure you use the english and not the french versionholdem.envholdem.exeholdem.exe.manifestXInput9_1_0.dllXInput9_1_0.dll.manifestP.S. Texas Holdem does not work for everybody
August 14, 200717 yr hey rick sorry to bug you again, but i still cant get texas hold'em to work...-installed alky for apps, and used my vista ultimate serial to ensure texas hold'em would work-logout, logged back in-downloaded texas hold'em cab-used hfextract on the cab-copied necessary files to %programfiles%\Microsoft Games\Texas Hold 'em\-used alky to patch necesary files...and still i cant get it to work. when i click on holdem.exe nothing happens. you said hold'em doesnt work for some people, is there some reason it wouldnt work on my computer??? :crying_anim02: Edited August 14, 200717 yr by runningfool
August 14, 200717 yr Author Same results for me... I cant help you with that, its just the luck of the draw.
August 14, 200717 yr considering im using a 2-year old laptop, im thinking hold'em isnt working because of a hardware problem. rick, are you on an older computer too? and have you had any luck with inkball?
February 14, 200817 yr Author Texas Holdem working on XP????Bye.Flashangel.Not with the old one, but yea its fixed on the new one (not sure when if ever he will release it)
February 14, 200817 yr well he has made the source code available, and more or less cancelled the project. i dont think hed object to someone compiling the source and uploading it somewhere
February 14, 200817 yr Author well he has made the source code available, and more or less cancelled the project. i dont think hed object to someone compiling the source and uploading it somewhere You are confusiong Alky with Alky for Applications (which has NOT been canceled)
February 14, 200817 yr NOT cancelled??? :thumbsup_anim:.......need...texas holdem... Edited February 14, 200817 yr by runningfool
February 23, 200817 yr NOT cancelled??? :thumbsup_anim:.......need...texas holdem...Try creating it in %programfiles%\Microsoft Games\HoldEm instead of %programfiles&\Microsoft Games\Texas Hold'Em or anywhere else!It worked for me! Edited February 23, 200817 yr by computer_genius
March 10, 200817 yr I would like the snipping tool ?It was posted on another forum, said you need VAIO XP/W2K3 for it to work but is VAIO now alky could someone explain this to me ?I tried the snipping tool and it did not work...
March 28, 200817 yr what tool will open and extract the file in holdem called "holdem.env" ?i've searched but i'm having no luck so any help would be great.thanks in advance.
March 29, 200817 yr what tool will open and extract the file in holdem called "holdem.env" ?i've searched but i'm having no luck so any help would be great.thanks in advance.Why would you want to do that?
March 29, 200817 yr Why would you want to do that?because iwanna see whats inside i guess. loli just figured there was an app that would extract it.is there no app that will open this file and extract it?i've searched and searched but have come up with nothing.anyone find out how to open this yet?please post if you do.thanks
