True Transparency
TrueTransparency is a freeware that changes the windows border adding png support and so true transparency.
size.png@ 316 KB
md5.png 37DA457BB23AAC7AA1354AC4886C5B5A
NOTE: Installation directory > Utilities
Changelog:
21-October-08 - Added international language support (DA,CA,EN,FR,DE,PL,IT,PO,ES,VI) removed forced startup entry to avoid overlapping,some .inf housing.
02-July-08 - updated to version 0.9.4
01-June-08 - Fixed inf that caused deleting folder on next system startup.
30-May-08 - updated to version 0.9.3
23-April-08 - updated to version 0.9.2
16-April-08 - updated to version 0.9.1
7- December - 07 .inf file improvements
5-November-07 - updated to version 0.8.5
29-October-07 - Fixed typo so now startup entry is fully removed when TT is uninstalled.
24-October-07 - updated to version 0.8.4 ,startup entry is enabled by default
05-September-07 - updated to version 0.6
21-August-07 - added TrueAero skin and also set as default skin
17-August-07 - fixed typo error causing Leopard skin not to load correctly.
16-August-07 - first release...includes add/remove entries.
True Transparency (editable) skin pack
size.png@1.13 MB
md5.png EB7E27F35C50A387FD017221AFAD7D4E
Editing Instructions
Download your favorite skin pack from here.
Download my skin pack that already includes Vista Pack Colors for TT 8.X skin pack, unpack my complete addon (Gorki_My_TT_skins_AddOn.cab) and right click open My_TT_skins.exe using any archiver you have installed in your OS...
As you see now you can add your favorite skin packs or delete ones that are already in archive... Just don't forget to unpack your favorite skin pack before adding it to My_TT_skins.exe
After that you repack everything,using any archiver as it was before and your favorite skin pack is ready for your new OS :)
Edited by Gorki
  • Replies 76
  • Views 112.6k
  • Updated the exellent .inf_addon from originally Gorki v0.9.4 to the newest with new additional skin "Seven" and improved stability Gorki_TrueTransparency_v1.3_Addon.7z
Try the link again...It's genuine authors page but can also be found here. Well about memory...did you see the screenshot above? On my machine it uses around 2.7k. Yes it's quite lightweight... :)
Gorky why don't you add a shortcut to the Startup folder (use my profileitems flags to make it universal)
Name	   =True Transparency,0x00000008,24
CmdLine =16422,%PROG_DIR%,TrueTransparency.exe
WorkingDir =16422,%PROG_DIR%
InfoTip =True Transparency
P.S. Needs no SubDir
Done! Addon now includes startup entry so it will be loaded on every boot :)
Fixed some typos, please read Changelog.
Edited by Gorki
Thanks Gorki! This is a really nice program. True Aero is my favorite!
a new version of True Transparency v0.6 is available
can you update it
help me gorki or rick :icon_question:
True Transparency v0.6 Download
http://www.crystalxp.net/galerie/en.id.513...lorer-tools.htm
Updated...program has some major changes as I see. Further more creator added Fr language and startup entry added as additional option.
I'm still leaving True Aero Skin as default one. :)
