Posted August 19, 200717 yr Here is a CMD file I made to slipstream Vista Icons, Boot & Login Screens and other stuff I collected from various Vista Shell Patchers (Energize, VistaMizer and VTP) V'ISO Build 8.2.2WARNING: For English RyanVM XP SP2 UpdatePack or XP SP3 users ONLY! (Make sure you have RVM or SP3, IE7 and WMP11 already slipstreamed/integrated before icon respatching)Also make sure you patch SFC (Windows File Protection.)Use at your own risk, I am not responsible if anything goes wrong. Updated (April 21-2008)MD5: E5BF931E9E0D95819BFC94607A84205DSize: 30.0 MBInstructions:- Slipstream RVM UpdatePack, IE7 and WMP11 (you can also slipstream addons, make unattended and remove components and other stuff)- Launch the SFX (self extracting installler)- Browse to the location of the i386 folder- Hit "Patch..." and wait awhile- Burn ISO and test it using VMwareChangelog: Quote Build 8.2.1 4-21-08- Added Vista OOBE images (thanks to orbit30)- Added a few extra files (thanks to amnesia)- Fixed Copy, Move, Delete dialog bug (thanks to chaox2)Build 8.2 4-06-08- Now extracts and patches in from WMP11, MEDIACTR and SP2/3 cabinets (fixes bootscreen issue)- Simplified CMD window textBuild 8.1.1 4-04-08- Added ntmsmgr.dll resources (thanks to amnesia)- New Vista Run dialog box (thanks to fediafedia)Build 8.1 3-13-08- Removed "More Information" button and text from Copy, Move, Delete dialog- Also added "About" before "Minutes/Seconds remaining" for a more Vista like dialog- Fixed netid.dll icon bug (preview)Build 8 2-29-08- Updated Move, Copy and Delete AVI's (also resized dialog box)Build 7.3 2-08-08- Nothing major just a few misc updated resources thanks to amnesiaBeta 7.2 1-25-08- Few misc updates (nothing major)Beta 7.1 1-10-08- Updated PEChecksum v1.3- Now includes MSC files (thanks to amnesia)- Patches a couple extra i386 DLL and EXE files (pointed out by amnesia)Beta 7 1-07-08- Fixed shrunken Start Button bug (thanks to amnesia)- Fixed Event Viewer bug (partially but still needs tweaking)- The green Vista Copy, Move and Del AVI's are back (also the dialog box tweak by neo)- Updated a couple other Copy, Del, Attributes AVI's (thanks to Sm0k3r)Beta 6 12-25-07- Fixed windbrand.dll bug (thanks to bober)- No longer removes Logoff/Shutdown text- Removed Cursors from user32.dll- Removed green Vista AVI's and Dialog box mod (now uses more "XP like" copy, move, delete AVI's and the default dialog box layout)
August 22, 200717 yr Does this installer include vista icons also? Here is WINNTBBU that gives winXP more visitsh style. I use it every time, It's must have for my xp collection. Quote Sorry Gorky but I deleted this file, it causes errors when I use it and I dont want anybody to experience the sameMD5: 44109B034E04690CB08776F751F95309picture preview is included in attachment I did not make it so I'm not responsible for any credits or such kind . I find if browsing MSFN Forums.
August 22, 200717 yr Author Thanks the setup screen is perfect.This patches/slipstreams more than 300 files with icons and bitmaps from various Vista shell patcher's.
August 27, 200717 yr Thanx a lot rick, i thing u can make it as a final version instead of beta, i have tested several times and it works flawlessly.thanks again for your great work.
September 15, 200717 yr I'm so sad, the boot screen never working for me. What's wrong?I don't know what else not working with this patcher.May I know what are the details of this patcher so I can check what are not working.Thanks
September 16, 200717 yr ricktendo64 said: Updated Beta 2Hi Rick, My first post in your neck-of-the-woods. This looks awesome!Ummm, your link is down. http://www.sokoolz.com is down...temporary problem?
September 16, 200717 yr Just wondering, does this include styler,icons,cursors,sounds,siebar,vistart,viorb,lclock?
September 16, 200717 yr Author No you integrate those using the addons and nLite before you do this... This only patches Icons, bmp's and avi's.
September 16, 200717 yr Mr_Smartepants said: Hi Rick, My first post in your neck-of-the-woods. This looks awesome!Ummm, your link is down. http://www.sokoolz.com is down...temporary problem?Some users have trouble accessing Sokoolz site. If you still experience problems we can relocate the package.
September 17, 200717 yr N1K said: Some users have trouble accessing Sokoolz site. If you still experience problems we can relocate the package.I even tried disabling the Symantec firewall but the site is still down with a "Server not found" error, although I can get to the Google cached site (no downloads though).Any rehosting would be greatly appreciated. :thumb_yello:
September 17, 200717 yr Author Beta 3 is upCan somebody download and MediaFire this?If I do, it will take 1 hour. I got a really slow connection
September 17, 200717 yr ricktendo64 said: Can somebody download and MediaFire this?Why MediaFire mate if we got free space on Zxian's server with creditentials Wolf provided :confused02: I'll upload this one mate..
September 17, 200717 yr even for fast connections its very slow and you are in the process of updatingthink of a way of splitting this into groups.like : group 1 :basic: group 2 :Pinocchio: group 3 :Cinderella: group 4 :miss America: .etcthen when you're satisfied put it back together ...anyways here is a mirror: Edited September 18, 200717 yr by ricktendo64 Removed link to buggy version
