ricktendo Posted September 4, 2007 Posted September 4, 2007 TopDesk v1.5.3 Trial (Easily updated to full)Info: This is the trial version but you can easily edit the addon if you have the Full version.MD5: 717BCE967ADB65C3307FF1CCF961794FUpdate Instructions:If you already have the full version of TopDesk and you want to update the addon from Trial to Full simply unpack the addon and the .CAB archive to sub-dirs and replace these 3 files in TopDesk.cabtopdesk153.dlltopdesk.exeuninst.exeRepack the addon as it was before but use this .INF file instead: Quote
xman Posted September 5, 2007 Posted September 5, 2007 Could anyone pls suggest name of program to replace files in a cab file? Quote
iuli_kyle Posted September 5, 2007 Posted September 5, 2007 Could anyone pls suggest name of program to replace files in a cab file?7-Zip, free, open source and light. You also may use WinRAR, WinZIP and so on. Quote
ricktendo Posted September 5, 2007 Author Posted September 5, 2007 7-Zip, free, open source and light. You also may use WinRAR, WinZIP and so on.7zip cannot do it... I use TugZIP Quote
bigrandalo Posted September 5, 2007 Posted September 5, 2007 IZArc would be another tool that supports cab Quote
xman Posted September 6, 2007 Posted September 6, 2007 7zip cannot do it... I use TugZIPI can open the cab file with tugzip, winrar or similar programs, unfortunately none of these are allowing to replace the file (drag & drop). Quote
ricktendo Posted September 6, 2007 Author Posted September 6, 2007 Not drag and drop (read my instructions "unpack the addon and the .CAB archive to sub-dirs") Quote
JurgenDoe Posted September 16, 2007 Posted September 16, 2007 How about TopDesk 1.6.0 :icon_question: any addons for this :crying_anim02: Quote
ricktendo Posted October 18, 2007 Author Posted October 18, 2007 Latest TopDesk version on the official site is 1.5.3. Quote
MadMaxX Posted June 13, 2008 Posted June 13, 2008 can u pls update to the latest version....thnx Quote
kiki burgh Posted June 16, 2008 Posted June 16, 2008 (edited) hello! TopDesk & DeskSpace are very handy applications ... would there be freeware alternatives for both? thanks! Edited June 16, 2008 by kiki burgh Quote
honey Posted June 17, 2008 Posted June 17, 2008 (edited) Ricky Please can u update this tool to 1.5.4 Edited June 17, 2008 by honey Quote
