Posted September 13, 200618 yr theme by PgaseLuna Royale v3.2 With White Start Button MD5: 704E55DC1CEA9F42E9D85239FBC898EDSize: 471 KB Website: http://www.deviantart.com/deviation/40772637/Luna Royale v3.2 With Color Start Button MD5: B0317493A6E52E7D8339493857DDB22CSize: 467 KB Website: http://www.deviantart.com/view/39360556/Luna Royale v3.2 With Orb Start Button MD5: DCC00917D819055DBDC4676AF1F0C970Size: 480 KBWebsite: http://www.deviantart.com/deviation/32413451/Optional Componnents: XPize:mario: Edited March 20, 200718 yr by ricktendo64
September 25, 200618 yr Author skins PgaseLuna RoyaLClockMD5: 5E7741F738C369FADCDC1CEE7A26A83BSize: 565 KBSwitching Between Blue & Black ClocksIn order to switch the LClock colors from Blue to Black to Blue... Right Click and choose LClock Properties, now select the Calendar tab and manually edit BlueButtons.bmp to BlackButtons.bmp, then BlueBG.bmp to BlackBG.bmp and vice versa. Edited November 15, 200618 yr by ricktendo64
October 26, 200618 yr I tried this one Rick, (Luna Royale v2.1 With Orb Start Button) and i love it.. thanksScOOt3r!
December 29, 200618 yr I like the look of the black theme with the color start button. Thanks a lot for these Rick! Thanks to Pgase for making these themes too Edited December 29, 200618 yr by cygnus
February 9, 200718 yr Hi,I don't want to undermine you, but would you be kind enough to provide instructions to manually integrate this within the $OEM$ folder structure?Fantastic release, but I'd rather make a permanent integration instead of having to re-apply the add-on each time I start with a fresh source.Lastly - do I require a hacked uxtheme.dll in order to use these?Thanks.laze.
February 9, 200718 yr Author LinkSimply put it into a folder named $OEM$\$$\Resources\ThemesYou don't need a uxtheme patch if you are using the Integrator but if you use nLite you have to chosse to patch
February 11, 200718 yr Right,So, during RyanVM's integration process is the uxtheme.dll modified? Or is it the method that's used which means modification to the uxtheme.dll isn't required?laze.
February 12, 200718 yr Author Look inside the entries.ini file of the addon and you will see the commads to tell the integrator to patch uxtheme.dll (nLite ignores this so not to worry)[HexEdit]I386\uxtheme.dll|6.0.2900.2180|113178|83EC1C568D4DE4|33C0C9C2040090I386\uxtheme.dll|6.0.2900.2523|104714|83EC1C568D4DE4|33C0C9C2040090I386\uxtheme.dll|6.0.2900.2845|104746|83EC1C568D4DE4|33C0C9C2040090
February 13, 200718 yr Hey,So my best bet really, is to just include a patched uxtheme.dll in my source to begin with.laze.
February 13, 200718 yr Hey,I've integrated the theme now but I'd like to set "Luna Royale (Alternative)" as the default variation rather than "Luna Royale" - is this possible and if so, how so?laze.
February 14, 200718 yr Hey,Nevermind, I've figured it out, I was just being impatient.laze.ps. Feel free to clean your thread by removing my mass of largely useless posts :-).
