Size - 633 kb MD5Hash = D22F52962024481FF6A04A06C783656B
This one actually use less than 400kb of ram while running (Its sitting at 364 right now in my system)
Plus Wolf included 256x256 icons for dock users!
Silent installer!!!
Coupla notes about this silent installer you can also use this to replace the original Vista Drive indicator incase you like the dark style and is also uninstallable.
i just connect my other hard drive back. and it appear to be the orginal icon. not the Indicator one. how can i fix this? my c: drive appear though
no creator it's not a removable drive. it's HDD. i connected it after windows installation. Creator please help me. i do not wish to reinstall window again.
Ok all written up just grab and run the silent installer. It will stop vistadrive.exe and restore the original icons. Then it will copy new icons to vistadrive folder to ensure you have all of the proper icons and restart vistadrive.
Then browse to your computer after like 30 seconds and all should be fine.
Remember this is a SILENT INSTALLER only double-click on it once! Clicking on it 50x will just bog youre system down and may cause errors. There will be no confirmation boxes or popups it just does its job.
