Everybody knows how to use ProfileItems to add/del shortcuts for your programs. And everybody knows the basic flags (so I will skip this part)
0x00000001 Create menu item in Current User flag
0x00000002 Delete menu item flag
0x00000004 Create Start menu group under All Users\Start\Programs
0x00000005 Create Start menu group under Current User\Start\Programs
0x00000006 Delete Start menu group under All Users\Start\Programs
0x00000007 Delete Start menu group under Current User\Start\Programs
Here is some exotic stuff you NEED and do NOT NEED to know about ProfileItems, including some new tips on how to add special types of shortcuts that do NOT go in the standard places like the All Programs group in your Start Menu.
QuickLaunch Shortcut Example
ProfileItems = Sidebar.QuickLaunch.AddShortcut
[Sidebar.QuickLaunch.AddShortcut]
Name = %SIDEBAR%,8,26
CmdLine = 16422,%SIDEBAR%,sidebar.exe
SubDir = %QUICK%
WorkingDir = 16422,%SIDEBAR%
InfoTip = "@%%ProgramFiles%%\%SIDEBAR%\sidebar.exe,-1012"
DisplayResource = "%%ProgramFiles%%\%SIDEBAR%\sidebar.exe",1000
[Strings]
SIDEBAR = "Windows Sidebar"
QUICK = "Microsoft\Internet Explorer\Quick Launch"
SendTo Shortcut Example
This is a double wammy, in addition of showing you how to add a shortcut to SendTo folder it shows how its possible to use ProfileItmes to make shortcuts to CMD and other files that were not possible before.
ProfileItems = Reg2Inf.SendTo.AddShortcut
[Reg2Inf.SendTo.AddShortcut]
Name = Reg2Inf,8,9
CmdLine = 11,,Reg2InfHandler.cmd
WorkingDir = 11
IconPath = 11,,shell32.dll
IconIndex = 71;<- Include this for DLL/EXE files with multipple icons
The secret of making links to files that cant normally be done using ProfileItems is IconPath and IconIndex, I point the CMD shortcut to the shell32.dll icon for CMD files but you can use any custom path to any icon. I prefer to point n7Epilson's Reg2Inf shortcut to regedit.exe like so
IconPath = 10,,regedit.exe;<-You dont need a IconIndex for this, IconPath uses the first executable/library icon by default.
How to add custom bookmark links for IE
You can also Delete Bookmarks... More info bellow
ProfileItems = RyanVM.AddBookmark
[RyanVM.AddBookmark]
Name = RyanVM's MSFN Files Page,8,6
URL = "http://www.ryanvm.net/msfn/"
IconPath = 16422,%IE%,IEXPLORE.EXE
IconIndex = 1
[Strings]
IE = "Internet Explorer"
Desktop & Folder Shortcut Example
Another double wammy, the following shows how to create a link to a Folder (%WinDir% or WINDOWS) in addition to creating it in %AllUsersProfile%\Desktop
ProfileItems = Desktop.WinDir.AddShortcut
[Desktop.WinDir.AddShortcut]
Name = WINDOWS,8,25
CmdLine = 10,,;<- Will NOT work without subdir commas
WorkingDir = 0;<- Very Important you use Zero
IconIndex = 3;<- Folder icon number in shell32.dll
Here are some of the special flags (more to come) you can use for all sorts of cool things (I have more flags but I wont post them because they lead to the Fonts and other useless directories)
Not all of them work during Windows Setup
0x00000008,2 = %UserProfile%\Start Menu\Programs
0x00000008,5 = %UserProfile%\My Documents
0x00000008,6 = %UserProfile%\Favorites <- Perfect for adding custom IE Bookmarks
0x00000008,7 = %UserProfile%\Start Menu\Programs\Startup
0x00000008,8 = %UserProfile%\Recent
0x00000008,9 = %UserProfile%\SendTo
0x00000008,11 = %UserProfile%\Start Menu
0x00000008,13 = %UserProfile%\My Documents\My Music
0x00000008,14 = %UserProfile%\My Documents\My Videos
0x00000008,16 = %UserProfile%\Desktop
0x00000008,19 = %UserProfile%\NetHood
0x00000008,20 = %WinDir%\Fonts
0x00000008,21 = %UserProfile%\Templates
0x00000008,22 = %AllUserProfile%\Start Menu
0x00000008,23 = %AllUserProfile%\Start Menu\Programs
0x00000008,24 = %AllUserProfile%\Start Menu\Programs\Startup
0x00000008,25 = %AllUserProfile%\Desktop
0x00000008,26 = %UserProfile%\Application Data <- Perfect for QuickLauch
0x00000008,27 = %UserProfile%\PrintHood
0x00000008,28 = %UserProfile%\Local Settings\Application Data
0x00000008,31 = %AllUsersProfile%\Favorites <- More IE Bookmarks
0x00000008,32 = %UserProfile%\Local Settings\Temporary Internet Files
0x00000008,33 = %UserProfile%\Local Settings\Cookies
0x00000008,34 = %UserProfile%\Local Settings\History
0x00000008,35 = %AllUsersProfile%\Application Data
0x00000008,36 = %WinDir%
0x00000008,37 = %WinDir%\system32
0x00000008,38 = %ProgramFiles%
0x00000008,39 = %UserProfile%\My Documents\My Pictures
0x00000008,40 = %UserProfile%
0x00000008,41 = %WinDir%\system32
0x00000008,43 = %CommonProgramFiles%
0x00000008,45 = %AllUsersProfile%\Templates
0x00000008,46 = %AllUsersProfile%\Documents
0x00000008,47 = %AllUsersProfile%\Start Menu\Programs\Administrative Tools
0x00000008,48 = %UserProfile%\Start Menu\Programs\Administrative Tools
0x00000008,53 = %AllUsersProfile%\Documents\My Music
0x00000008,54 = %AllUsersProfile%\Documents\My Pictures
0x00000008,55 = %AllUsersProfile%\Documents\My Videos
0x00000008,56 = %ResourceDir%
0x00000008,57 = %ResourceDir%409
0x00000008,59 = %UserProfile%\Local Settings\Application Data\Microsoft\CD Burning
In order to DELETE any of the same links as above using ProfileItems in your INF Uninstall, use the 0x0000000A,XX flag followed by the special number. Use the same one you used to add the link in the first place (just edit "XX").
Example: The following deletes "Windows Update.LNK" from %AllUsersProfile%\Start Menu
ProfileItems = MU.DelShortcut
[MU.DelShortcut]
Name=Windows Update,0x0000000A,22
  • 5 months later...
  • Replies 65
  • Views 42.2k
  • Just to share a few things. I got it set sucessfully as HotKey =0x653 ; hex 200 + 400 + 53 where 200 is Ctrl + 400 is Alt + 53 is S Thanks to ricktendo64, OnePiece & bphlpt for some thought &
  • I face the same situation as you. keycodes.exe is not much use when using combined keystroke. I relied on "200 = Ctrl + and 400 = Alt +" reference only. Found a more reliable alternative solution. Que
  • You could use UnregisterDLLs to call it or RunPreSetupCommands, either way this is how that would go (might only work with advpack.dll,LaunchINFSection) [UnregDLLsection] 16422,Utility\T-Clock2010\Wi
Neat tut, thanks rick :)
This helped me to create my sortcuts in current user directory. It doesnt seem so important, but some programs use that dir, and their uninstallers too.
great job.
But can I ask you a question for my nero addon shortcut?
The orginal Nero ControlCenter shortcut target line is
"C:\Program Files\Common Files\Nero\Nero Web\SetupX.exe" MODE="update"
and i want prepare it for my addon shortcut
This is my code in nero.inf for Nero ControlCenter shortcut
[Nero.Webcut]
Name =Nero ControlCenter
CmdLine =16427,"Nero\Nero Web",SetupX.exe MODE="update"
SubDir ="Nero\Setup"
WorkingDir=16422,"Nero\%PROG_NAME%"
IconPath =16427,"Nero\Nero Web",nps.dll
IconIndex =0
InfoTip ="Update The Legendary Burner!"
But when i install addon this shotcut target line is become to
"C:\Program Files\Common Files\Nero\Nero Web\SetupX.exe" MODE=update
so it doesn't work. How i add invert commas("") in shortcut target line?
Edited by Preputium64
Responded to your PM also (its easy, you just quote the quotes :P)
[Nero.Webcut]
CmdLine =16427,"Nero\Nero Web",SetupX.exe MODE="""update"""
WorkingDir=16422,"Nero\Nero Web"
;IconIndex =0 ;<-Don't need this, IconPath will automatically use the 1st icon by default
i`m having a problem in the cmd line the file name has a space in it
and i cant fix it
plz help.
Edited by Dark_Knight
THIS IS MY INF
[Version]
Signature="$Windows NT$"
[Optional Components]
FOXIT
[DefaultInstall]
AddReg =FOXIT.AddReg
CopyFiles =FOXIT.FILES
ProfileItems=Desketop.AddShortcut,Foxit.AddShortcut,Uninstall.AddShortcut
[FOXIT]
OptionDesc ="Foxit Pdf Reader"
Tip ="Small PDF reader"
Modes =0,1,2,3
[DestinationDirs]
FOXIT.FILES=16422,%FX%
[sourceDisksNames.x86]
1="WinXp","Foxit.Cab",,I386
[sourceDisksFiles]
FoxitReader.exe=1
Readme.txt=1
Uninstall.exe=1
[FOXIT.FILES]
Foxit Reader.exe,FoxitReader.exe
Readme.txt
Uninstall.exe
[FOXIT.AddReg]
HKCU,"Software\%FX%\FrameWnd","WindowPos",0x0,"2,3,-1,-1,-1,-1,22,29,982,583"
HKCU,"Software\%FX%\MainFrame","AdvertiseIndex",0x0,"8"
HKLM,"SOFTWARE\%FX%","isplugin",0x0,"0"
HKLM,"SOFTWARE\%FX%","isreaderpro",0x0,"0"
HKLM,"SOFTWARE\%FX%","InstallPath",0x0,"%16422%\%FX%\"
HKLM,"SOFTWARE\%FX%","Version",0x0,"2.3.2008.2923"
HKLM,"SOFTWARE\%FX%","IsForAllUser",0x0,"1"
[Desketop.AddShortcut]
Name ="Foxit Reader",8,25
CmdLine =16422,%FX%,%SH%
WorkingDir=-1
[Foxit.AddShortcut]
SubDir =%FX%
WorkingDir=-1
[uninstall.AddShortcut]
Name =Uninstall
CmdLine =16422,%FX%,Uninstall.exe
SubDir =%FX%
WorkingDir=-1
[strings]
FX="Foxit Software\Foxit Reader"
SH="Foxit Reader.exe"
it`s ok now i fixed it using this FOXITR~1.exe and it worked fine
and thx
and thx
Dude nice thinking :D
BTW I was going to do it but it was using a totally difrent way of adding shortcuts, I was just about to post it
thx i remembered the dos and that ~1 thing for tall folders and files
so i did the same and entered the dos and tried it and it worked
you should still post this new way i need to try it.
it might be better
and thx
Any special flag for %UserProfile%\Desktop (not %UsersProfile% neither %AllUsersProfile%) ?
Hi Ricks !
I'd like to create the shortcut below to uninstall my app (KO Approach). Does it work ?
[uninstall.Startcut]
Name =Uninstall KO Approach,0x00000008,23
CmdLine ="rundll32.exe advpack.dll,LaunchINFSection %17%\Approach.inf,Uninstall.KOA <-- THIS COMMAND
SubDir =KO Approach
WorkingDir=16422,KO Approach
IconPath =11,,shell32.dll
IconIndex =110
Thanks.
[Uninstall.Startcut]
CmdLine ="rundll32.exe advpack.dll,LaunchINFSection Approach.inf,Uninstall.KOA"
SubDir =KO Approach
IconIndex =110
This should work fine for you like that.
SubDir =KO Approach
IconIndex =110
[EDIT]
@ Kels
Failed. But lines below work fine :D :
Name =Uninstall %KOSOFT%,0x00000008,23
CmdLine =11,,rundll32.exe,"advpack.dll,LaunchINFSection Approach.inf,Uninstall.KOA"
WorkingDir =11,,
SubDir =%KOSOFT%
IconIndex =110
Tried & found work fine too
CmdLine =11,,rundll32.exe,"advpack.dll LaunchINFSection Approach.inf,Uninstall.KOA"
CmdLine =11,,rundll32.exe,advpack.dll "LaunchINFSection Approach.inf,Uninstall.KOA"
Thanx again for help.
Edited by Ken@fri
This is the way to do it
CmdLine =11,,"rundll32 advpack.dll LaunchINFSection Approach.inf,Uninstall.KOA"
Thanx, Ricks ( always too perfect, I see) :icon_cool: !
Edited by Ken@fri
  • 11 months later...
Hi everyone, I signed up to discuss an adventure I'm having with removing shortcuts created with ProfileItems.
First of all, ricktendo64 - thank you for sharing the info, it has been very useful.
Your example of deleting a shortcut is given here:
[MU.DelShortcut]
Microsoft, on the other hand, advocates a different method. They say the flag to be used is 0x00000002 (FLG_PROFITEM_DELETE)
The problem is that I've tried them both, both work on XP, but none works on Vista or Seven.
Here is the relevant part of the INF that I expect to do the job:
[CreateStartMenuFolderEx]
Name = %AppLink%
SubDir = %App_StartMenuFolder%
CmdLine = -1, %App_ProgramFolder%, File.exe ;-1 means Absolute path
WorkingDir = -1, %App_ProgramFolder%
[DelStartMenuFolderEx]
Name = %AppLink%,0x00000002
I suspect it may have something to do with how I call the shortcut removal section. I do it this way:
[DefaultUninstall]
ProfileItems=DelStartMenuFolderEx
At this point I have several questions:
  1. How did you discover the 0x0000000A flag?
  2. What do you think goes wrong during the attempt to remove the shortcut?
  3. Am I invoking the ProfileItems delete procedure correctly?
  4. The Name keyword takes 2 arguments, while you give it a third one - "22", what is it?
I hope some light can be shed on this problem.
well try
if i wasn't mistaken
you think about it
i tell you delete a file
?? you need to know it's place
that why you will need the subdir
the other advantage in using the A
is 0x0000000A,22 << that the 22 says the file place
so if i wasn't mistaken you wouldn't need the subdir
test and tell
(just switch "8" to "A" and it deletes the shortcut)
Yes you can also try/use either 0x00000002 or 0x00000003 to delete the shortcut.
You have to also take in mind when you run your script...remember this shortcut does not actually get created until syssetup.inf is executed, which happens somewhere around or before t13
Test your shortcut removal code on right now on your actual pc, if it works fine but not during setup then you should look at when you are executing it during the install
@egorz if you know a way to use CMD.EXE or some other tool I could maybe try to launch it with .INF but no, dont know how to do that
Thank you for the quick feedback. I've tried multiple approaches and the behaviour is the same - the shortcut is not removed.
Specifically, I tried the following:
  • with and without SubDir = %App_StartMenuFolder%
  • with "0x00000002", "0x00000003" and with "0x0000000A,22"
I am surprised that none of them work, because the documentation says they should, and your experience is also suggesting that deleting shortcuts this way must work.
I am thinking that in my case the problem is in the fact that the procedure is not invoked at the right time.
I also guessed it could have some thing to do with administrative privileges (or lack of them), but the results are the same even if I use "run as administrator".
What other ideas you think I could test?
try to change the 22
it's the file path
if %App_StartMenuFolder% mean
then the command should be
0x0000000A,2
to delete
