ricktendo Posted November 20, 2007 Posted November 20, 2007 ToolTipFixer 1.0.1 AddOn Make sure to install .Net Framework during SVCPACKMD5: 7AA50AD642361581E185444AA356E227Size: 39.3 KBWebsite: http://neosmart.net/wiki/display/TTF/NeoSmart Technologies' ToolTipFixerToolTipFixer is a "patch" of sorts by NeoSmart Technologies created to permenantly fix one of Windows' most annoying & oldest bugs to date. The "hidden tooltip" bug has been around since the days of Windows 95, and became progressively worse with each Windows Upgrade Quote
chaox2 Posted November 20, 2007 Posted November 20, 2007 do this program take some memory space or processor resource? Quote
MzQueenie Posted November 20, 2007 Posted November 20, 2007 wow finally a program that does that!!! thank you. Quote
MzQueenie Posted November 20, 2007 Posted November 20, 2007 do this program take some memory space or processor resource?i think around 6k and you gotta have .NET Framework installed Quote
Rhor Posted November 21, 2007 Posted November 21, 2007 Thanks Rick. Another one that will go into my XP CD.Im testing it now, and for me it takes 6 MB of RAM, having 2 GB and not using the Page File. Quote
foxxx428 Posted November 25, 2007 Posted November 25, 2007 That is an annoying bug. Haven't they fixed it in SP3? It doesn't exist in Vista. Quote
Mr.Thunderbird Posted November 25, 2007 Posted November 25, 2007 (edited) Thanks Rick! :thumb: :thumb: Edited November 25, 2007 by Mr.Thunderbird Quote
bober Posted December 8, 2007 Posted December 8, 2007 im almost certain that this app has issues,example with winamp some windows are ontop and others are under,it seems to 'play' like this ...its a good fix fore the ballon tip but there are some issues making me question the app's usefullness,btu otherwise thx for the addon. Quote
DEViANCE Posted December 8, 2007 Posted December 8, 2007 Are you sure its not fixed in sp3, i used to get this all the time using sp2 and winblinds, but not had it once using sp3 and msstyles. I once installed the vista inspirate pack and it happend a lot then also.... Quote
Helmi Posted December 13, 2007 Posted December 13, 2007 Are you sure its not fixed in sp3, i used to get this all the time using sp2 and winblinds, but not had it once using sp3 and msstyles. I once installed the vista inspirate pack and it happend a lot then also....I have just installed SP3 RC1 today and seeing your post, I immediately gave it a try to "provoke" this error (simply right-click on an entry in the Start menu) and, unfortunately, I can confirm that this has NOT been fixed in SP3 (so far).Seeing as it's RC1, I estimate the chances to have this fixed for final rather slim...I'm not sure how it is with Vista and SP1 RC1, thpugh... Quote
Greg S Posted January 20, 2008 Posted January 20, 2008 I used the website link for download and tried it. It works fine but for me it causes a dark semi transparent shadow to appear over the Windows Sidebar which will appear on alternating clicks of any gadget within the sidebar. In other words if the shadow is not present on the sidebar and I click a gadgets button then the shadow overlays the right half of the sidebar causing the button of the gadget to not function. The only way the button will function when the shadows present is if I double click it real fast. Quote
ricktendo Posted January 20, 2008 Author Posted January 20, 2008 I used the website link for download and tried it. It works fine but for me it causes a dark semi transparent shadow to appear over the Windows Sidebar which will appear on alternating clicks of any gadget within the sidebar. In other words if the shadow is not present on the sidebar and I click a gadgets button then the shadow overlays the right half of the sidebar causing the button of the gadget to not function. The only way the button will function when the shadows present is if I double click it real fast.OMG thank you so much, I have been looking for the cause of that sidebar bug for a loooooong time... Thought it was Alky Quote
wrx Posted January 21, 2008 Posted January 21, 2008 WOW I thought it was another add on causing the problem thanks Greg Quote
Greg S Posted January 21, 2008 Posted January 21, 2008 OMG thank you so much, I have been looking for the cause of that sidebar bug for a loooooong time... Thought it was Alky Yea, I've tried and am using quite a few of the goodies offered here and like them very much especially that sidebar thingy. I use app blocking through firewall which blocked all but this so it was kinda easy to figure which it was. I still can't believe MS has not fixed this tooltip problem. For me it rarely happens but is always a result of when the taskbar is selected to be on top of other windows which is also a semi problem for me when using the visual tooltip app. If my mouse is over the taskbar open program the visual tooltip shows and works prefectly but if I have to use the right click context menu the visual tooltip disappears as it should leaving the context menu cut off at the bottom due to the fact that taskbar is selected to be on top of other windows. On a side note, Rick thanks for all the cool factor AddOns. I've really enjoyed trying these out in the past week. Also what, whether it be here or elsewhere, would be the best option for achieving the Vista look for XP? I've seen some(quite a few) of your screenshots and like the look of it. Any tips/pointers would be appreciated. Thanks Quote
MrNxDmX Posted January 22, 2008 Posted January 22, 2008 Nice util. It's bad that we cant do it via registry.Thanks for sharing rick. Quote
KsbjA Posted May 15, 2008 Posted May 15, 2008 Very cool, but... how are we going to slipstream it? It says '[AddOn]', but I can't find any addon for nLite... It would be awesome to integrate it :-) Quote
ricktendo Posted May 15, 2008 Author Posted May 15, 2008 What do you mean?With nLite if you want to integrate addons you add it in with the hotfixes Quote
mara- Posted May 17, 2008 Posted May 17, 2008 I read somewhere that this bug is fixed with SP3.Cheers Quote
ricktendo Posted September 28, 2008 Author Posted September 28, 2008 Dont use this if you use the sidebar Quote
cotty59uk Posted October 2, 2008 Posted October 2, 2008 Thanx Rick, Very much appreciated Mate. Quote
