Full list of things that are included.
Custom Wallaper applied duiring installation:
v1.7 Change Log
Fixed a vunerability in gdiplus.dll with a updated version of the file. (Thanks kurt_aust)
Open CMD Here v1.0.5
v1.6 Change Log
Regshot v2.0.1.66
Hashtab v2.1.1
Open CMD here v1.0.4
UPXGui v1.8
Notepad2 v3.0.20-rc2
Unlocker v1.8.7
Taskkill v5.1.2600.5512
v1.5 Change Log
MAJOR UPDATES!
Added Taskkill.exe (Needed for uninstall routines) v5.1.2600.0
Metapath v3.2.0.19
UPXGui v1.6
Fixed missing CLSID4 string
HashTab v2.0.8
Made a custom uninstall routine for Unlocker
Coupla typo fixes
v1.3 Change Log
Had to remove MakeCab update :(
v1.2 Change Log
Wall-cmd was updated to use .jpg files instead of .bmp files...
v1.1 Change Log
Fixed the missing Wallpaper Changer entries
Main Additions
Compumatrix WallPaper Changer v2.1
Metapath v3.2.0.19
Microsoft OpenType\TrueType Font Properties Extension v2.30
NotePad2 v3.0.20-rc2
Quicklaunch is now enabled by default.
RefreshEM
RegShot v2.0.1.66
Replacer v2.63
Taskkill v 5.1.2600.5512
Unlocker v1.8.7 (Includes Unlocker Assistant and is uninstallable)
SendTo Menu Additions <-- All Uninstallable!
CabTool v1.8
FGCBA v0.897
Reg2Inf v0.46
Resource Hacker v3.4.0.79
UpxGui v1.8
Shell Extensions
.dll/.ocx/.ax Register/Unregister Regtweak
Advanced .inf install/uninstall Regtweak
Back v3
Copy To/Move To
Create ISO on right click
File Extension Toggle v3
Find Target v3
HashTab v2.0.8
Hidden Files Toggle v3
Mainsoft ClipName v1.2.3
ModifyPE
Open in a new window
Select All v3
Synesis File Case v2.0.2.31
Synesis Run with arguments v2.0.2.32...
...and a custom Power Menu to contain most of the shell extensions
Size - 4.38 megs MD5Hash = 29EB2A899BC0DD8746CC10743FCB4FFF
SpiritPyres 4 extensions (Back, Hidden Files Toggle, File extensions Toggle and Select all) Can be customized through the following registry file:
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions]
Refresh Key=e
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\BrowserBack]
@=&Back
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\FileExtToggle]
@=&File Extension Toggle
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\HiddenFilesToggle]
@=&Hidden Files Toggle
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\SelectAll]
@=&Select All
Just Change the titles to whatever you want and then apply!
Brought to you by KelCorp!
  • 4 months later...
Hi Kel,
Nice addon, I hope theres enough interested to keep this maintained.
The Microsoft OpenType\TrueType Font Properties are not working, looks like UberPack.inf is missing:
[strings]
CLSID4 = "{afc638f0-e8a4-11ce-9ade-00aa00a42d2e}"
Also theres a few updates:
Unlocker v1.8.5 --> v1.8.7
UpxGui v1.5 --> v1.6
HashTab v2.0.5 --> v2.0.8
MetaPath v3.1.08 --> v3.2.09
Looking around I cant find what value the MetaPath adds, apart from being a plug-in for NotePad2. Hope you can shed some light. :huh:
Theres also an update for Regalyzer v1.5.5 --> v1.5.8.10 from the Win 2000 Personal Pack.
Love you addon's, they add great value, keep up the great work. :D
Cheers
7yler
Posted (edited)
Hi Kel,
[strings]
look at the top of the forum in the "stickies" this thread is old/outdated... 12.2 (w/notepad2 2.0.18*codes*) and uberpack w/notepad++ are both in the "stickies" and have been updated, the only one slightly out of date is the notepad++ one which is at 4.8.5 for notepad++
EDIT: Mods, this thread should be locked and maybe kel can just edit his first post to have a link to the new thread, so as not to confuse anyone else.
Edited by benjammin
@ benjammin = this pack is made for win2000 ONLY and yes it is outdated. When I get a litte time i will update it. Hopefully toinight :D .
sorry... just noticed that... haha... my bad!
  • 4 months later...
  • 11 months later...
  • 1 year later...
  • 7 months later...
  • 7 years later...
