Kelsenellenelvian Posted November 30, 2007 Posted November 30, 2007 Homepage -- http://www3.sympatico.ca/lazimute/programs.htmBuild2:Updated Makecab.exe and Cleaned the .ini upThis little baby cabs and dacabs both files and folders!I also included the makecab.exe from Win 2008 v6.0.6001.18000Size 67.8 kb MD5Hash = 911C9348DB2A650AAEF5E84CF08BCCEETested and works on Win2000, XP and Win2003 Quote
anonymous Posted November 30, 2007 Posted November 30, 2007 I installed the addon manually and when I send a file to CabTool I get this error: Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 Let me double check it Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 look in your system32 dir for expand and makecab Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 I see absolutly nothing wrong in my addon.It is such a simple addon to ok goto your system32 dir and copy cabtool.exe to your desktop and drop a file on it... Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 Ok I made a coupla adjustments to it. Please try again. Quote
anonymous Posted November 30, 2007 Posted November 30, 2007 (edited) Same error. Edited November 30, 2007 by anonymous Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 Thats the only thing I can see wrong but it should still work if makecab and expand are in there.I have an idea hold on. Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 http://www.wpiw.net/downloads/Kels_XPero_e..._addon_v1.5.cabGive this a try (.net 2 is required) Quote
anonymous Posted November 30, 2007 Posted November 30, 2007 (edited) That addon gives me this error:Maybe you could just make a CAB Tools for SendTo folder addon that uses the .VBS file to install. That way does work for me. Edited November 30, 2007 by anonymous Quote
Kelsenellenelvian Posted November 30, 2007 Author Posted November 30, 2007 DO you have cabarc and modifype?I think we may be missing cabarc.I don't know how to run a vbs script through an inf so I will ask rick when he awakens if he knows. Quote
ricktendo Posted November 30, 2007 Posted November 30, 2007 To call VBS files I use RunPost/PreSetupCommandsRunPostSetupCommands=SectionName:1[SectionName]CMD /Q /C CD /D """%LDID%\%VBS_DIR%""" & CSCRIPT vbs_file.vbsKel since RunPostSetupCommands wont work during Windows setup I use a RegisterDLLs trick to launch my INF section and use advanced INF, exampleRegisterDLLs=Launch.INF[Launch.INF]11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %INF_FILE%,Setup"[Setup]RunPostSetupCommands=xxxxxxxx Quote
anonymous Posted November 30, 2007 Posted November 30, 2007 BTW I have both cabarc and modifype. Quote
anonymous Posted November 30, 2007 Posted November 30, 2007 Ok Im not sure what I did but I got the second addon (eXpander) working. Quote
lib9 Posted April 2, 2008 Posted April 2, 2008 kels can you reup this addon please the link is out. Quote
Kelsenellenelvian Posted April 3, 2008 Author Posted April 3, 2008 Actually the link was fine the button was just broken... Quote
Mr_Smartepants Posted April 3, 2008 Posted April 3, 2008 Any idea on how to get cabtool -> sendto working under Vista? Not an addon question, I know, but one that's been bugging me. Quote
Kelsenellenelvian Posted April 3, 2008 Author Posted April 3, 2008 Not that I have found yet... Quote
0d14r3 Posted April 6, 2008 Posted April 6, 2008 Hi, Kelsenellenelvian.Do you have a Cabpack in SendTo style?0d Quote
MrNxDmX Posted April 7, 2008 Posted April 7, 2008 Hey mate, here's makecab.exe file from server 2008 rtm. And, you need to remove this code from entries.ini for RVMi 1.5.1:rvmtemp\extracted\Makecab.exeAlso please remove ur sid from website link MD5 of 7z file: 1BF0835D282479A4A0D00C26CF2C54ADMD5 of exe file: 85EFC7BCBF6327B9C7FA774D374313CCWhat about a peChecksum send to style addon?CheersW2K8_MakeCab.7z Quote
