Posted December 12, 200717 yr Moved here:http://www.wincert.net/forum/index.php?showtopic=3023 Edited March 31, 200817 yr by orbit30
December 12, 200717 yr Nice work orbit30. I like this blue one! Please provide MD5 hash and @ size...when posting addon.
December 12, 200717 yr Blue is so cold.I do like the fact you edited the regular bootscreen, could you make some more colors avalaible ? :thumbsup_anim: like grey en whitety
December 12, 200717 yr I second that; could you have the original color for the progressbar available using the Windows XP SP3 files?
December 13, 200717 yr Author Im working on a bunch of them around 10 colours in total. Red 1 finished grey next in line. :beerchug:
December 13, 200717 yr a challeng for you, sir:get the vista bootscreen working for 64-bit XP. "Restorator 2007" is the only resource modder i know that will work on 64-bit files...
December 13, 200717 yr Nice one. Yeah, it would be nice to have other colors, but take your time and thanks for sharing.
March 28, 200817 yr Author what string did you edit to change the color?Edit Bitmaps - Reshacker, adobe photoshop, color (4-bit) Palette
March 28, 200817 yr Do those images need to be open in PS to be able to see the green bar ? Sorry im so lost
March 28, 200817 yr Author Do those images need to be open in PS to be able to see the green bar ? Sorry im so lostOpen the bitmaps in 'A-P-S' select image/mode/color table now select your 4bit color pallete you can try it also in boot edit.The progress bar bitmaps are 22x9 Edited March 28, 200817 yr by orbit30
