Kelsenellenelvian Posted December 27, 2007 Posted December 27, 2007 To add silent installers in as hotfixes in nlite you copy the following code into notepad and fill in the blanks. Then save as entries_****.ini (Make the **** into the progs name to prevent double file errors)[general]Title = Version = Description = Language = BuildDate =Website =[EditFile]I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram[AddProgram]Program.exe <---- Place the installers name here!Then add the installer into a folder called svcpack in the same directory as the .ini file and rar, zip, 7z or cab them. then simply add as an hotfix in nLite...As for the RVM integrator it now takes switchless installers just as they are. Quote
Guest DennyMK Posted December 25, 2008 Posted December 25, 2008 This is good to know in case you don't have nLite Add-On Maker.Thanks Quote
Guest snakecracker Posted December 25, 2008 Posted December 25, 2008 Thanks kel on this tut.now i know how to do this and make addons :sweatingbullets: Quote
feared Posted January 3, 2009 Posted January 3, 2009 Is there a need for /S after the Program.exe to make it Silent? for example: [general]Title =7-ZipVersion =4.63Description =7-Zip is a file archiver for Windows 95/98/ME/NT/2000/2003/XP/VistaLanguage =74 languagesBuildDate =01/02/2009Website =http://www.7-zip.org/[EditFile]I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram[AddProgram]7z463.exe /S <----------Thanks! Quote
Guest DennyMK Posted January 3, 2009 Posted January 3, 2009 Is there a need for /S after the Program.exe to make it Silent? for example: [AddProgram]7z463.exe /S <----------Thanks!Yes, that's the silent switch (command which doesn't allow the visibility of the program installation). Quote
feared Posted January 3, 2009 Posted January 3, 2009 Yes, that's the silent switch (command which doesn't allow the visibility of the program installation).Thanks Denny. I tried the 7z addon that I created and used this ini file but received a 7-zip failed load error during the windows installation of MCE in VMware.Back to the drawing board. :doh: Quote
Guest DennyMK Posted January 3, 2009 Posted January 3, 2009 Thanks Denny. I tried the 7z addon that I created and used this ini file but received a 7-zip failed load error during the windows installation of MCE in VMware.Back to the drawing board. :doh:Maybe you should download a few add-ons, unpack them and see how they supposed to be created. :type: By the way, don't give up... :tumbleweed: Quote
feared Posted January 3, 2009 Posted January 3, 2009 Maybe you should download a few add-ons, unpack them and see how they supposed to be created. :type: By the way, don't give up... :tumbleweed:Thanks again. No worries, I got it figured out. :manual: I downloaded the 7z that Reaper upload very recently http://www.wincert.net/forum/index.php?sho...amp;#entry39942 and studied it, created my own, and it just successfully installed in VMWare.I think I have all of Reapers addons now :thumbsup_anim: Cheers! Quote
SIMurq Posted January 31, 2009 Posted January 31, 2009 Yes, that's the silent switch (command which doesn't allow the visibility of the program installation).That gets me confused again and again, guys! At different forums I see that people recommend AutoIt to make the unattended install of addons silent. But now I can see that you recommend to use the silent switches. So, why do I need AutoIt then?!? E.g., I want to make some changes in pre-install windows of Winamp (like disable Winamp Library and visualizations) - before they all are installed on my computer. When I make it through SVCPACK method with a simple silent switch, it installs with all these features installed - this is what I don't want to happen. Now, when I heard about the capabilities of AutoIt I was quite happy to use it. I even wrote a script which makes the whole process of install quite seamless. But when it comes to switches, I really get confused - 'coz some say AutoIt allows for switchless install and some say - one still needs to use switches for different installers.Which one 's true, for God's sake! Quote
Sumondatta Posted June 25, 2009 Posted June 25, 2009 hey mates,i need to know what switch would be right for WINDOWS LIVE MESSENGER that is a .msi file.and also if u give an example of Entries INI it would be greatly appretiated. :help: Quote
ricktendo Posted June 25, 2009 Posted June 25, 2009 You cant launch a .msi file from svcpack, you have to either usea a msi launcher (msistub.exe) or you could also use a .cmd file and use example.msi /qn /norestartBTW you it wont install during svcpack, you need to mod it with this tutorialIf you search around ryanvm.net/msfn, msfn.org and here you may find some addons already made Quote
Sumondatta Posted June 26, 2009 Posted June 26, 2009 thanks mate.i saw that qn and norestart switch doesn't work in Svpack mode.anyway i will do whatever you say. Quote
