Repackaged, fully silent and tested!
With the help of several forum members this addon now does the following:
Disables the Java Quick Start utility
Removes the update check (Even removes the tab for update checking)
PLUS insted of installing JRE as a seperate version it will now update the existing installation!!! (I always HATED that part)
Packaged on 2011/02/17
Switches used = /qn ADDLOCAL=ALL IEXPLORER=1 MOZILLA=1 SYSTRAY=0 JAVAUPDATE=0 JU=0 AUTOUPDATECHECK=0 MODIFYREMOVE=modify
This is the config entry =
;!@Install@!UTF-8!
GUIMode="2"
RunProgram="Java6u17.msi /qn ADDLOCAL=ALL IEXPLORER=1 MOZILLA=1 SYSTRAY=0 JAVAUPDATE=0 JU=0 AUTOUPDATECHECK=0 MODIFYREMOVE=modify"
RunProgram="hidcon:cmd /c \"%programfiles%\\Java\\jre6\\bin\\jqs.exe\" -unregister"
RunProgram="regedit /s java.reg"
;!@InstallEnd@!
With this reg file:
[HKEY_CURRENT_USER\Software\JavaSoft\Java Update\Policy]
"EnableAutoUpdateCheck"=hex:01,00,00,00,d0,8c,9d,df,01,15,d1,11,8c,7a,00,c0,4f,\
c2,97,eb,01,00,00,00,9e,9b,bf,c2,27,b9,97,4f,9e,f0,76,37,a6,00,59,2b,00,00,\
00,00,1c,00,00,00,50,00,61,00,73,00,73,00,77,00,6f,00,72,00,64,00,20,00,44,\
00,61,00,74,00,61,00,00,00,10,66,00,00,00,01,00,00,20,00,00,00,dc,20,72,03,\
cd,3e,fb,cf,34,34,20,b4,69,52,58,ce,54,aa,93,6e,ed,44,31,b7,64,70,e3,1e,67,\
3a,81,c5,00,00,00,00,0e,80,00,00,00,02,00,00,20,00,00,00,19,16,10,6f,3a,80,\
e2,41,b7,60,ac,08,9b,3e,ca,86,ac,d8,6a,a2,ef,46,80,3b,ff,c8,f2,07,00,8c,23,\
a3,10,00,00,00,66,88,0e,7c,44,3c,ef,7b,ab,f0,2e,9a,87,17,34,48,40,00,00,00,\
6d,e8,dc,6a,1a,a5,5c,41,c5,d8,dc,6d,7d,c7,45,c3,3b,e5,57,d8,33,c5,ba,3c,9e,\
16,15,38,30,d7,1b,d0,93,b0,e0,24,9a,44,ba,39,c5,aa,e4,cc,71,53,8b,b2,ba,f8,\
e5,02,0d,d0,a5,be,e4,db,30,a0,aa,e4,5d,fc
[HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Update\Policy]
"EnableAutoUpdateCheck"=dword:00000000
"EnableJavaUpdate"=dword:00000000
"NotifyDownload"=dword:00000000
"NotifyInstall"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"SunJavaUpdateSched"=-
"How did I get the .msi and related files?"
Run the bare installer and after it extracts, but before you agree to install, goto the %appdata% dir then back one dir and into the locallow folder, sun folder then you will find the .msi and files in there.
Once you get there run this command:
msiexec.exe /a jre***.msi targetdir=%homedrive%\Admin /qb (Note you MUST create the Admin dir at the root of c: first.)
Then 7zip up the files\folders in the admin folder...
NOW FOR THE INSTALLERS!!!
Size = 11.5 megs MD5Hash = f35d97ce4613c600dc3bd72ff852fe9c
Sorry no addon no more it is wayy too easy for you to make an entries file for yourself.
Plus the integrator takes switchless installers now....
:questionmark: Hi Kelsenellenelvian and Happy New Year! One thing I've noticed is that on the official Java website "http://java.sun.com/javase/downloads/?intcmp=1281" yesterday was the update 4 but was like impossible to download! Today they put back the old version 3! Any idea about that and how did you get your? Do you think that if we install your downloaded one something wrong could happen? Thanks to let us now and all the best from Zagreb, Hrvatska.
The Courageous Cat.
I have heard it is simply due to server overload from auto-update. But I dunno for sure.
I have Just update 4 on my main and laptop (Im anal about being updated) and run limewire and a couple of other java related apps and no issues yet.
Personally i consider it good and safe. BUT If you guys feel the neew I will rebuild 3 for you and upload it.
Hi Kelsenellenelvian, thanks for your reply. Leave the update 4 as it is, we'll see if bugs happen but I'm still wondering why Sun reversed to update 3 on their website????? By the way I haven't seen a new DirectX 9 update yet, strange!
Take care and all the best,
the courageous cat
QUOTE from the sticky section!
To add silent installers in as hotfixes in nlite you copy the following code into notepad and fill in the blanks. Then save as entries_****.ini (Make the **** into the progs name to prevent double file errors)
[general]
BuildDate =
Description =
Language =
Title =
Version =
Website =
[EditFile]
I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram
[AddProgram]
Program.exe <---- [b]Place the installers name here![/b]
Then add the installer into a folder called svcpack in the same directory as the .ini file and rar, zip, 7z or cab them. then simply add as an hotfix in nLite...
As for the RVM integrator it now takes switchless installers just as they are.
  • 4 weeks later...
Hello, I was just wondering (if you know) why after installing java via your addon, a file named java_install_reg.log is created in my %temp% folder and says:
Process start at 04/03/2008-09:56:07.
== Start JNICALL Java_com_sun_deploy_util_UpdateCheck_shouldPromptForAutoCheck ==
Process start at 04/04/2008-10:32:27.
I have not used Java for at least a couple of days. So, I don't think it's just when it's accessed that it adds to this log.?
Also, after installing, If you open java from the control panel auto update is still checked. If you un check it, it asks you if you're sure as if it was really checked before.
I just thought it was weird because auto update is turned off in the registry right?
I'm using Java 6 update 5.
Java Runtime Environment v6.0 Update 10 is out :please:
Accoring to the download link it's only Beta
