*Reaper* Posted January 11, 2008 Posted January 11, 2008 (edited) Windows IP Configuration Manager 2.7.2.80 CPL AddonAbout Win IP ConfigWin IP Configuration Manager is a replacement for the annoying command line tools "ipconfig.exe" and "route.exe". This version also includes the "netstat.exe" tool.Win IP Configuration Manager shows you the IP settings of the installed network interfaces. IP addresses obtained by DHCP can be renewed by Win IP Config.Routes can easily be added, removed, changed or made persistent by this tool.Network interfaces can administratively be enabled or disabled, repectively. Throughput statistics can be watched for each of the network interfaces in a separate window. The program has full capabilities with Windows 2000, Windows XP and Windows Vista. Some functions are not supported under Windows 98. Windows ME should behave like Windows 98, but this has not been tested.News in Version 2.7.1 / 2.7.2 (bugfix for Windows Vista) Made DHCP Renew accessible from main menu / button bar.Minor usability enhancements.This software does not run with NT4 and Windows 95.Changelog:1-12-08- Fixed some more errors in the inf- Fixed some errors in the inf1-10-08- Initial ReleaseInformation: InfoVersion: 2.7.2.80Credit: Reaper (aka Makave2345 or Me)Uninstallable?: YesSize: 764 kbMD5: 65844F2BEC85E10B3E1E6AAC390F08DBSHA1: 240A891CDEA9167DB250BEF8E1C97302E681CFB9CRC-32: 5D3B73A6Enjoy! Edited February 27, 2008 by *Reaper* Quote
Gorki Posted January 11, 2008 Posted January 11, 2008 Nice work Makave. Thank U! :thumbsup_anim: Quote
*Reaper* Posted June 5, 2011 Author Posted June 5, 2011 I'm currently on vacation.. I will reup when I return.. Quote
