Posted January 30, 200817 yr Shock 4Way 3D v1.2INFO: Shock 4Way 3D increases your desktop space, allowing you to work and play on multiple desktops.Website: http://update.docs.kr/entry/Download-Summary-enMD5 - CE9DB391B8908F5B80D559ED80760E24Size - 7.21 MBTo add your Registry information:Extract the 7z.Extract the .cabReplace the "Shock4Way3D.xml" with yours. (this can be found after you manually install the program and have registered it in C:Program Files\Shock Utility\Shock4Way3D)Recab the filesZip it back up and install Edited February 2, 200817 yr by LUZR4LIFE
May 26, 200816 yr im not really sure if this is the right place to put this, but i need help withShock 4way 3d, i have downloaded it, and it works, My system is Windows Vista (on my 1st comp)i want to make it so the 4 different desktops have different internets up at the same time, because, when i pull up, say google, it pulls it up in all 4 desktops...And i know what i want is possible because my 2nd computer a Windows XP does what im asking for, and all of my preferences are the same,What do i need to do?
May 26, 200816 yr Author I have no ideal. I don't use this. I use YODM for Vista and DeskSpace for XP.
May 28, 200816 yr nice addon, but i believe these reg entries should be deleted from ure inf:HKCU,"Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached","{3F30C968-480A-4C6C-862D-EFC0897BB84B} {0000010B-0000-0000-C000-000000000046} 0x401",0x1,01,00,00,00,36,00,30,00,8e,c0,28,3b,cb,62,c8,01HKCU,"Software\Microsoft\Windows\Shell\Bags\1\Desktop","ItemPos800x600(1)",0x1,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,18,00,00,00,02,00,00,00,14,00,1f,60,40,f0,5f,64,81,50,1b,10,9f,08,00,aa,00,2f,95,4e,18,00,00,00,52,00,00,00,64,00,31,00,00,00,00,00,3d,38,77,95,10,00,43,4f,4e,56,45,52,7e,31,2e,32,35,38,00,00,48,00,03,00,04,00,ef,be,3d,38,90,93,3d,38,5d,a1,14,00,00,00,43,00,6f,00,6e,00,76,00,65,00,72,00,74,00,58,00,74,00,6f,00,44,00,56,00,44,00,2e,00,76,00,32,00,2e,00,32,00,2e,00,33,00,2e,00,32,00,35,00,38,00,00,00,1c,00,98,02,00,00,a2,00,00,00,5e,00,32,00,65,6d,80,00,3d,38,40,b8,20,00,53,45,54,55,50,5f,7e,31,2e,45,58,45,00,00,42,00,03,00,04,00,ef,be,3d,38,3d,b8,3d,38,40,b8,14,00,00,00,53,00,65,00,74,00,75,00,70,00,5f,00,53,00,68,00,6f,00,63,00,6b,00,34,00,57,00,61,00,79,00,33,00,44,00,2e,00,65,00,78,00,65,00,00,00,1c,00,98,02,00,00,42,01,00,00,5e,00,32,00,5f,1c,18,00,3d,38,41,b8,20,00,53,45,54,55,50,5f,7e,32,2e,45,58,45,00,00,42,00,03,00,04,00,ef,be,3d,38,41,b8,3d,38,41,b8,14,00,00,00,53,00,65,00,74,00,75,00,70,00,5f,00,53,00,68,00,6f,00,63,00,6b,00,41,00,65,00,72,00,6f,00,33,00,44,00,2e,00,65,00,78,00,65,00,00,00,1c,00,98,02,00,00,42,01,00,00,00,00,00,00HKLM,"SYSTEM\CurrentControlSet\Services\kmixer\Enum","0",0x0,"SW\{b7eafdc0-a680-11d0-96d8-00aa0051e51d}\{9B365890-165F-11D0-A195-0020AFD156E4}"so reg entries section should look like this:[Shock4Way3D.AddReg]HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu2\Programs\Shock Utility",,0x10HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu2\Programs\Shock Utility","Order",0x1,08,00,00,00,02,00,00,00,32,01,00,00,01,00,00,00,02,00,00,00,84,00,00,00,00,00,00,00,76,00,00,00,41,75,67,4d,02,00,00,00,01,00,00,00,64,00,32,00,14,03,00,00,3d,38,60,b8,20,00,53,48,4f,43,4b,34,7e,31,2e,4c,4e,4b,00,00,3a,00,03,00,04,00,ef,be,3d,38,60,b8,3d,38,60,b8,14,00,00,00,53,00,68,00,6f,00,63,00,6b,00,20,00,34,00,57,00,61,00,79,00,20,00,33,00,44,00,2e,00,4c,00,4e,00,4b,00,00,00,1c,00,0e,00,00,00,0a,00,ef,be,00,00,00,00,1c,00,00,00,00,00,00,00,00,00,a2,00,00,00,01,00,00,00,94,00,00,00,41,75,67,4d,02,00,00,00,01,00,00,00,82,00,32,00,b9,05,00,00,3d,38,60,b8,20,00,55,4e,49,4e,53,54,7e,31,2e,4c,4e,4b,00,00,58,00,03,00,04,00,ef,be,3d,38,60,b8,3d,38,60,b8,14,00,00,00,55,00,6e,00,69,00,6e,00,73,00,74,00,61,00,6c,00,6c,00,20,00,53,00,68,00,6f,00,63,00,6b,00,20,00,34,00,57,00,61,00,79,00,20,00,33,00,44,00,20,00,76,00,31,00,2e,00,32,00,2e,00,4c,00,4e,00,4b,00,00,00,1c,00,0e,00,00,00,0a,00,ef,be,00,00,00,00,1c,00,00,00,00,00,00,00,00,00HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Shock 4Way 3D v1.2",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Shock 4Way 3D v1.2","DisplayName",0x0,"Shock 4Way 3D v1.2"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Shock 4Way 3D v1.2","UninstallString",0x0,"""%10%\IFinst27.exe"" -U%16422%\Shock Utility\Shock4Way3D\IFU29.inf" Edited May 28, 200816 yr by bober
