Posted (edited)
PowerISO v3.9
INFO: PowerISO is a powerful CD/DVD image file processing tool, which allows you to open, extract, create, edit, compress, encrypt, split and convert ISO files, and mount these files with internal virtual drive. It can process almost all CD-ROM image files including ISO and BIN.
Main Features:
  • Support almost all CD/DVD-ROM image file formats(ISO, BIN, NRG, CDI, DAA and so on).
Note: DAA(Direct-Access-Archive) is an advanced format for image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes. It can be handled directly just like other formats, such as ISO, BIN, ...
Open and extract ISO File.
  • Create ISO file from hard disk files or CD/DVD-ROM.
  • Edit an existing ISO file directly.
  • Convert image files between ISO/BIN and other formats. PowerISO can convert almost all image file formats to standard ISO format file.
  • Make bootable ISO file, get boot information from bootable ISO file.
  • Make floppy disk image file.
  • Optimize files to save disk space while saving ISO file.
  • Mount ISO file with internal virtual drive. You don't need install any other virtual drive software.
  • Can be used easily. PowerISO supports shell integration, context menu, drag and drop, clipboard copy paste...
Website: http://www.poweriso.com/
MIRROR
MD5 - E33C94890E2C27CADD9E2842D6D1A315
Size - 961 KB
Edited by LUZR4LIFE
does ure addon associate the file types?
No, I don't believe so. Sorry, I was making a few addons, when I was doing this one, but if any, it would just be ISO.
sorry my question, but I'm not understand..
how to insert register (my name and serial) in addon?
please help
Sorry, but I have yet to find out how for this program. As soon as I do I will update the topic.
Register the program and in regedit go to
[HKEY_CURRENT_USER\Software\PowerISO] and look for "USER" your serial number is the hex string.
Hey Sm0k3r, thanks but I tried that and it didn't work,t I will try it again.
Will see what I can do, as I don't use your addon but I install it silently and then apply the reg after install.
OK, thanks. I have been building a computer today so I haven't had time since I left to get the parts earlier. Hopefully tomorrow I can try some more things out.
