I made a step by step video on how to make a Zune theme addon.
Recommended:
Kels UberPack (you can manually install this)
CMenu or Send2A3X (by MHz)
Advanced INF (Use this instead of OSR PDF)
.Net Framework 2.0 (required for FGCBA)
7-Zip (also required for FGCBA)
ZuneDesktopTheme
Video:
Zune All Parts (111 MB)
FGCBA Test (62.7 MB)
Other:
ZuneThemeAddOn (final addon)
The reason I chose a theme is because it is what I started with and I think, so should you.
Man this is a great video tut Rick I also liked your VistaBasicTheme tut you did a while ago but there really is nothing like seeing and hearing a well thought out lesson. Thanks so much, I really appreciate your efforts. :icon_cool:
The video helped enormously especially with focusing the viewer towards the processes involved rather than a series of steps.
I am planning on making a new unattended and I saw what seemed to be a cool 'pop up' app every now and then in your videos. Can you please tell me what the app was and what it's for.. It seemed to be some sort of quick link access app? :questionmark:
That is part of Camtasia Studio, which was used for recording the desktop.
Posted (edited)
No its not LUZR, you are way off :D
Its simply Alt+Tab, cant believe you guys would not know this keyboard shortcut :P
LMAO. OOOOOPS. I thought you said that you hit Alt+Tab while in Camtasia to get that. SOOOOORRY :P
Edited by LUZR4LIFE
I was just perusing and came back upon this. Didn't think to check back on it because of LUZR's reply.
I never new about the Alt+Tab 'thingy'. I would have gone on and never thought twice about this again.
I've used alt+tab before but just to minimize a game window or bring up a current web page while surfing with no other folders or apps open so never observed the pop up menu before.
Glad I asked the question... In this case "Ignorance was far from bliss". 36_11_8.gif
Alt-Tab function was renamed to Task Switcher in Vista.... Makes total sense now. 36_17_6.gif
Here's a wiki link for anyone that wants some more info on this matter.
Removed OSR PDF, use ADVANCED INF instead
HOW to change default Visual Style and background
You use WINNT.SIF to accomplish this, just make a your theme addon add this to WINNT.SIF
[Shell]
CustomDefaultThemeFile="%ResourceDir%\Themes\Windows XP Vistaluna Basic.Theme"
; Generated by nLite 1.4.5 beta
[Data]
Autopartition=0
MsDosInitiated=0
UnattendedInstall="Yes"
[Unattended]
UnattendMode=FullUnattended
UnattendSwitch="No"
OemPreinstall="Yes"
OemSkipEula="Yes"
FileSystem=*
WaitForReboot="No"
NoWaitAfterTextMode=1
NoWaitAfterGUIMode=1
DriverSigningPolicy=Ignore
NonDriverSigningPolicy=Ignore
Hibernation="No"
[GuiUnattended]
AdminPassword=*
TimeZone=xxx
OEMSkipRegional=x
OemSkipWelcome=x
[Components]
[UserData]
ProductKey="xxxxxxxxxxxxxxxxxxxxxx"
ComputerName=*
FullName="xxx"
[RegionalSettings]
LanguageGroup=xx
Language= "xxxx"
[Networking]
InstallDefaultComponents="Yes"
[WindowsFirewall]
Profiles=WindowsFirewall.TurnOffFirewall
[WindowsFirewall.TurnOffFirewall]
[Shell]
Mode=0
  • 3 months later...
Hello Rick ^^
First Thing Your Amazing man For Make This Tut. Video , and u Make it Realy Easy
and i got proplem ! LoL
can u see this Images And any1 one tell me why ?!
what is string %Cdname%
and must change remos.cab ,8.3 filename example:123remos.cab
  • 6 months later...
Recommended:
ZuneDesktopTheme
Video:
Zune Part 1 (13.1 MB) Mirror
Zune Part 2 (6.38 MB) Mirror
Zune Part 3 (19.1 MB) Mirror
Zune Part 4 (23.7 MB) Mirror
Zune Part 5 (21.4 MB) Mirror
Zune Part 6 (13.3 MB) Mirror
Zune Part 7 (23.2 MB) Mirror
FGCBA Test (39.1 MB) Mirror
Other:
Off Topic: The reason I chose a theme is because it is what I started with and I think, so should you.
Part 3 RS link down plz reuploaded
thx in advance
