Posted October 16, 200618 yr CMenu v2.6by Michael Heath (aka MHz)Website: http://mywebsite.bigpond.com/michaelpheath/cmenu/MD5: 7542CFEC6C5D5B827CDA109A9401A01ASize: 2.56 MB CMenu is a handy, context menu extension. Adds a branch to your context menu called More Options. It is so handy, that you will save alot of time for those tedious tasks, that CMenu can do so easy. Look below at all the features, for you to enjoy.* Uses PEiD, which is able to recognize installer types, if available in it's the database. Identify Installer uses this information, and is able to popup a window to show parameters associated with that installer. Identify Installer can unpack, admin, record, silent installations, if available. And also create a template AutoIt Script, to suit.* Includes CMenu Editor. This allows further customizing.* Files can Execute With Parameters, optional working directory, and allowing for different window states.* Create a Directory List. Preset options are available, as well as a custom options.* Create an AutoIt Archive Script, that can be included into your main scripts. This allows AutoIt to act like an archiver.* Includes PEiD as a separate item also, which allows the user to enhanced, portable executable identification.* Filenames and paths can be easily sent to the windows clipboard, by using Path To ClipBoard.* Allows for the user to download and add Resource Hacker or Stud PE. These will be detected, if placed in the correct folder, and will be added to the context menu.* MyUninstaller is included in CMenu.* Force Delete is included in CMenu. Use this only, as required. When deleting multiple files, do not do anything, until the operation is complete. A msgbox will popup and will allow, not to proceed. Use at own risk.* AutoItMacroGenerator is included to handle recording of AutoIt install scripts.* Reg2Au3 quickly converts Regedit4 type registry files to AutoIt3 syntax.* Ini2Au3 quickly converts Ini files into AutoIt syntax.* Constants Generator retrieves the constants declarations that your AutoIt script only needs.* 7-Zip2Sfx for easily converting 7z archives to self extracting archives.* RegKey2AU3 quickly converts a Registry Key into AutoIt3 syntax.SendToA3X v1.7by Michael Heath (aka MHz)Website: http://mywebsite.bigpond.com/michaelpheath/sendtoa3x/MD5: 587872D09DE51799D12F1C2E490E84A7Size: 1.22 MB SendToA3X is a very handy SendTo extension. Adds shortcut links to your SendTo menu for any included extensions and executables. It is so handy, that you will save alot of time for those tedious tasks, that SendToA3X can do so easy. Look below at all the features for you to enjoy.*7-Zip2Sfx for easily converting 7z archives to self extracting archives.*AutoItMacroGenerator is included to handle recording AutoIt scripts for unidentified installers.*AutoIt Archive Script can create archive script from a source folder. This allows AutoIt to act like an archiver.*AutoIt Execute Script Gui can execute a single au3/a3x file or select from a folder to execute an au3/a3x file.*AutoIt Execute Script StdOut can capture the stdout from a au3/a3x file and show a window after execute of the output.*Classes By Text can capture the ControlID's from a selected window.*Remove comments from AutoIt3 scripts quickly with Comment Remover.*Constants Generator retrieves the constants declarations that your AutoIt script only needs.*Create a Directory List. Preset or custom options are available.*Files can Execute With Parameters, optional working directory, and allowing for different window states.*Ini2Au3 quickly converts Ini files into AutoIt syntax.*Filenames and paths can be easily sent to the windows clipboard, by using Path To ClipBoard.*Reg2Au3 quickly converts Regedit4 exported files into AutoIt3 syntax.*RegKey2Au3 quickly converts a Registry Key into AutoIt3 syntax.*Convert VBScript to AutoIt3 scripts using Vbs2Au3.*Includes PEiD as a separate item also, which allows the user to enhanced portable executable identification. Edited March 15, 201015 yr by ricktendo64
March 9, 200817 yr Hey Rick....If it isn't too much trouble, could you update sendto to 1.6??? :worthy: Here is the new website also...http://mywebsite.bigpond.com/michaelpheath/sendtoa3x/
June 3, 200816 yr Rick SendToA3x has been updated to v1.7 any chance of you updating this addon please.SendToA3x
June 4, 200816 yr Author requestYep...This is the reason I don't use SendToA3X, instead I use CMenu because its much less noticeableEasy request, all that is needed to do is add SubDir=%STA3X% to all the SendTo ProfileItems (note the program uninstaller will not delete them on uninstall);--------------------------------; r i c k t e n d o 6 4 2 0 0 8;--------------------------------[Version]Signature="$Windows NT$"[Optional Components]SendToA3X[DefaultInstall]CopyFiles =Main.Files,Compiled.Files,Files.Files,AMG.Files,Templates.Files,PEiD.Files,Plugins.Files,PluginsDK.Files,Source.Files,Files.x2,Include.FilesAddReg =Uninstall.AddRegProfileItems=Help.AddShortcut,SendTo.AddShortcut,Au3A.AddSendTo,Au3AS.AddSendTo,Au3CT.AddSendTo,Au3CR.AddSendTo,Au3CG.AddSendTo,Au3ESG.AddSendTo,Au3ESS.AddSendTo,Au3I2A.AddSendTo,Au3MG.AddSendTo,Au3R2A.AddSendTo,Au3Rk2A.AddSendTo,Au3TAuR.AddSendTo,Au3TMG.AddSendTo,Au3V2A.AddSendTo,F7z2Sfx.AddSendTo,FDL.AddSendTo,FExwP.AddSendTo,FIdIn.AddSendTo,FP2Clip.AddSendTo,FSnd2.AddSendTo,PEiD.AddSendTo[SendToA3X]OptionDesc ="SendToA3X"Tip ="A Very handy Send To extension"Modes =0,1,2,3CopyFiles =Main.Files,Compiled.Files,Files.Files,AMG.Files,Templates.Files,PEiD.Files,Plugins.Files,PluginsDK.Files,Source.Files,Files.x2,Include.FilesAddReg =Uninstall.AddRegProfileItems=Help.AddShortcut,SendTo.AddShortcut,Au3A.AddSendTo,Au3AS.AddSendTo,Au3CT.AddSendTo,Au3CR.AddSendTo,Au3CG.AddSendTo,Au3ESG.AddSendTo,Au3ESS.AddSendTo,Au3I2A.AddSendTo,Au3MG.AddSendTo,Au3R2A.AddSendTo,Au3Rk2A.AddSendTo,Au3TAuR.AddSendTo,Au3TMG.AddSendTo,Au3V2A.AddSendTo,F7z2Sfx.AddSendTo,FDL.AddSendTo,FExwP.AddSendTo,FIdIn.AddSendTo,FP2Clip.AddSendTo,FSnd2.AddSendTo,PEiD.AddSendTo[SourceDisksNames.x86]1="%STA3X% Files","STa3x.cab",,"i386"[DestinationDirs]Main.Files =16422,%STA3X%Compiled.Files =16422,%COMPLD%Files.Files =16422,%FILES%AMG.Files =16422,%AMG%Templates.Files=16422,%TEMPLATE%PEiD.Files =16422,%PEID%Plugins.Files =16422,%PLUGINS%PluginsDK.Files=16422,%PLUGDK%[SourceDisksFiles]AutoItMacroGenerator02.exe=1AutoIt_-_Archiver.a3x=1Autoit_-_Automated_Script.a3x=1AutoIt_-_Classes_By_Text.a3x=1AutoIt_-_Comment_Remover.a3x=1AutoIt_-_Constants_Generator.a3x=1AutoIt_-_Execute_Script_Gui.a3x=1AutoIt_-_Execute_Script_StdOut.a3x=1AutoIt_-_Ini2Au3.a3x=1AutoIt_-_MacroGenerator.a3x=1AutoIt_-_Reg2Au3.a3x=1AutoIt_-_RegKey2Au3.a3x=1AutoIt_-_Tidy_Au3Recorder_Script.a3x=1AutoIt_-_Tidy_MacroGenerator_Script.a3x=1AutoIt_-_Vbs2Au3.a3x=1Automate_with_WinExists.au3=1Automate_with_WinExists.txt=1Automate_with_WinWait.au3=1Automate_with_WinWait.txt=1Common_Functions.au3=1defs.h=1external.txt=1Extra_Functions.au3=1File_-_7Zip2SFX.a3x=1File_-_Directory_List.a3x=1File_-_Execute_with_Parameters.a3x=1File_-_Identify_Installer.a3x=1File_-_Path_To_Clipboard.a3x=1File_-_SendTo (create shortcut).a3x=1GenOEP.dll=1Ghost.au3=1Ghost.txt=1ImpREC.dll=1innounp.exe=1Inno_Setup.au3=1Inno_Setup.txt=1InstallShield_2003.au3=1InstallShield_2003.txt=1InstallShield_AFW.au3=1InstallShield_AFW.txt=1InstallShield_Unpacked.au3=1InstallShield_Unpacked.txt=1kanal.dll=1kanal.htm=1License.txt=1null.c=1NULL.dll=1Nullsoft.au3=1Nullsoft.txt=1PEiD.exe=1RAR_SFX.au3=1RAR_SFX.txt=1readme.txt=1SendToA3X.exe=1SendToA3X_Help.chm=1Settings.ini=1Tarma.au3=1Tarma.txt=1TheHook.dll=1unins000.dat=1unins000.exe=1userdb.txt=1UserScript.au3=1VISE.au3=1VISE.txt=1Windows_Installer.au3=1Windows_Installer.txt=1WinZip.au3=1WinZip.txt=1Wise.au3=1Wise.txt=1ZDRx.dll=1ZIP_SFX.au3=1ZIP_SFX.txt=1[Main.Files]License.txtSendToA3X.exeSendToA3X_Help.chmSettings.iniunins000.datunins000.exe[Compiled.Files]AutoIt_-_Archiver.a3xAutoit_-_Automated_Script.a3xAutoIt_-_Classes_By_Text.a3xAutoIt_-_Comment_Remover.a3xAutoIt_-_Constants_Generator.a3xAutoIt_-_Execute_Script_Gui.a3xAutoIt_-_Execute_Script_StdOut.a3xAutoIt_-_Ini2Au3.a3xAutoIt_-_MacroGenerator.a3xAutoIt_-_Reg2Au3.a3xAutoIt_-_RegKey2Au3.a3xAutoIt_-_Tidy_Au3Recorder_Script.a3xAutoIt_-_Tidy_MacroGenerator_Script.a3xAutoIt_-_Vbs2Au3.a3xFile_-_7Zip2SFX.a3xFile_-_Directory_List.a3xFile_-_Execute_with_Parameters.a3xFile_-_Identify_Installer.a3xFile_-_Path_To_Clipboard.a3xFile_-_SendTo (create shortcut).a3x[Files.Files]innounp.exePEiD.exe[AMG.Files]AutoItMacroGenerator02.exeTheHook.dll[Templates.Files]Automate_with_WinExists.au3Automate_with_WinExists.txtAutomate_with_WinWait.au3Automate_with_WinWait.txtCommon_Functions.au3Extra_Functions.au3Ghost.au3Ghost.txtInno_Setup.au3Inno_Setup.txtInstallShield_2003.au3InstallShield_2003.txtInstallShield_AFW.au3InstallShield_AFW.txtInstallShield_Unpacked.au3InstallShield_Unpacked.txtNullsoft.au3Nullsoft.txtRAR_SFX.au3RAR_SFX.txtTarma.au3Tarma.txtUserScript.au3VISE.au3VISE.txtWindows_Installer.au3Windows_Installer.txtWinZip.au3WinZip.txtWise.au3Wise.txtZIP_SFX.au3ZIP_SFX.txt[PEiD.Files]external.txtPEiD.exereadme.txtuserdb.txt[Plugins.Files]GenOEP.dllImpREC.dllkanal.dllkanal.htmZDRx.dll[PluginsDK.Files]defs.hnull.cNULL.dll[Help.AddShortcut]Name =%STA3X% HelpCmdLine =16422,%STA3X%,SendToA3X_Help.chmSubDir =%STA3X%WorkingDir=16422,%STA3X%[SendTo.AddShortcut]Name =SendTo Folder (open),0x00000008,23CmdLine =16393,,SubDir =%STA3X%WorkingDir=-1IconPath =11,,shell32.dllIconIndex =3[Au3A.AddSendTo]Name =AutoIt - Archiver,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Archiver.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3AS.AddSendTo]Name =Autoit - Automated Script,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\Autoit_-_Automated_Script.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3CT.AddSendTo]Name =AutoIt - Classes By Text,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Classes_By_Text.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3CR.AddSendTo]Name =AutoIt - Comment Remover,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Comment_Remover.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3CG.AddSendTo]Name =AutoIt - Constants Generator,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Constants_Generator.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3ESG.AddSendTo]Name =AutoIt - Execute Script Gui,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Execute_Script_Gui.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3ESS.AddSendTo]Name =AutoIt - Execute Script StdOut,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Execute_Script_StdOut.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3I2A.AddSendTo]Name =AutoIt - Ini2Au3,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Ini2Au3.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3MG.AddSendTo]Name =AutoIt - MacroGenerator,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_MacroGenerator.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3R2A.AddSendTo]Name =AutoIt - Reg2Au3,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Reg2Au3.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3Rk2A.AddSendTo]Name =AutoIt - RegKey2Au3,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_RegKey2Au3.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3TAuR.AddSendTo]Name =AutoIt - Tidy Au3Recorder Script,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Tidy_Au3Recorder_Script.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3TMG.AddSendTo]Name =AutoIt - Tidy MacroGenerator Script,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Tidy_MacroGenerator_Script.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[Au3V2A.AddSendTo]Name =AutoIt - Vbs2Au3,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\AutoIt_-_Vbs2Au3.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[F7z2Sfx.AddSendTo]Name =File - 7Zip2SFX,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\File_-_7Zip2SFX.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[FDL.AddSendTo]Name =File - Directory List,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\File_-_Directory_List.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[FExwP.AddSendTo]Name =File - Execute with Parameters,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\File_-_Execute_with_Parameters.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[FIdIn.AddSendTo]Name =File - Identify Installer,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\File_-_Identify_Installer.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[FP2Clip.AddSendTo]Name =File - Path To Clipboard,0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\File_-_Path_To_Clipboard.a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[FSnd2.AddSendTo]Name =File - SendTo (create shortcut),0x00000008,9CmdLine =16422,%STA3X%,"SendToA3X.exe ""Compiled\File_-_SendTo (create shortcut).a3x"""SubDir =%STA3X%WorkingDir=-1IconPath =16422,%STA3X%,SendToA3X.exe[PEiD.AddSendTo]Name =PEiD,0x00000008,9CmdLine =16422,%PEID%,PEiD.exeSubDir =%STA3X%WorkingDir=-1[Uninstall.AddReg]HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: Setup Version",,"5.2.2"HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: App Path",,"%16422%\%STA3X%"HKLM,"%UNINSTALL%\%STA3X%_is1","InstallLocation",,"%16422%\%STA3X%\"HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: Icon Group",,"%STA3X%"HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: User",,"ricktendo64"HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: Setup Type",,"full"HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: Selected Components",,"main,autoit,file,peid"HKLM,"%UNINSTALL%\%STA3X%_is1","Inno Setup: Deselected Components",,"source,installscript"HKLM,"%UNINSTALL%\%STA3X%_is1","DisplayName",,"%STA3X%"HKLM,"%UNINSTALL%\%STA3X%_is1","DisplayIcon",,"%16422%\%STA3X%\SendToA3X.exe"HKLM,"%UNINSTALL%\%STA3X%_is1","UninstallString",,"""%16422%\%STA3X%\unins000.exe"""HKLM,"%UNINSTALL%\%STA3X%_is1","QuietUninstallString",,"""%16422%\%STA3X%\unins000.exe"" /SILENT"HKLM,"%UNINSTALL%\%STA3X%_is1","DisplayVersion",,"1.7.0.0"HKLM,"%UNINSTALL%\%STA3X%_is1","Publisher",,"Michael Heath"HKLM,"%UNINSTALL%\%STA3X%_is1","NoModify",0x10001,01,00,00,00HKLM,"%UNINSTALL%\%STA3X%_is1","NoRepair",0x10001,01,00,00,00HKLM,"%UNINSTALL%\%STA3X%_is1","InstallDate",,"20080603"[Strings]STA3X ="SendToA3X"COMPLD ="SendToA3X\Compiled"FILES ="SendToA3X\Compiled\Files"AMG ="SendToA3X\Compiled\Files\AMG"TEMPLATE ="SendToA3X\Compiled\Templates"PEID ="SendToA3X\PEiD"PLUGINS ="SendToA3X\PEiD\plugins"PLUGDK ="SendToA3X\PEiD\pluginsdk"UNINSTALL="SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"
February 15, 200916 yr New version of PEidhttp://www.peid.info/0.95 Phoenix:Fixed some crashing bugs.Minor Core update.Crash Fix in Securom detection.Also does CMenu take place of the USSF (Universal Switch Finder)? I wanted to install CMenu on an existing WinXP and the links from the main CMenu thread are broken. I did find an EXE installer posted by someone, but an hesitant to run it without an MD5. Can someone post an MD5 for the CMenu 2.6 EXE installer.
February 15, 200916 yr Author Can someone post an MD5 for the CMenu 2.6 EXE installer. File: CMenu.exeCRC-32: 29c97d58 MD4: 731139db64e6df0d5e95557691030e4c MD5: b8690f8de1d5a2f5e0a8e95f66cfb3ea SHA-1: 3f8f674b67c2069449b54529008cc7b6de89f23aBTW thanks for the peid update info
February 15, 200916 yr File: CMenu.exeCRC-32: eac12f07 MD4: 6e13f8e65dc75cdb21eae900175b50d1 MD5: 16abb87b7f090b930379c9bc23f5cd71 SHA-1: 6979ef02510c0944bdf00a3dcec12d8e4fd2129c
November 24, 200915 yr hi rick! only the sendtoa3x mirror link posted by trax works. thanks! Edited November 24, 200915 yr by kiki burgh
March 15, 201015 yr Thanks for being so attentive!By the way, Off topic, but related, I tried to download your Silent Switch Maker from here, but when I tried to download it from your SkyDrive, I got a "Remote server or file not found" error.Thanks again, and sorry to put you through all the file maintenance hassles.Cheers and Regards
