LS Patch v1.1 by Windows X
MD5: 775292CAF1DB34A0737D863E45D78E67
Website: http://www.windowsxlive.net/
Patches explorer.exe to hide the Logoff/Shutdown Start Menu Text
Installs Shortcut to Start->All Programs->Utilities
  Quote
Changelog in version 1.1
-Preserve default text if resources extraction fails
-Revert explorer.exe back if patching fails
Features:
-Simple and easy
-Works on all XP/2003
-Support non-English OS (every language)
-related strings in stringtable 439 won't be modified.
Edited by ricktendo64
Wolf I got a modded VistaCG theme with a difrent shellstyle.dll and it also some screensavers and mplayer11/Vista LClocks with SegoeUI fonts that will go great with the HighSpinns cursors.
You can also go here and get a Vista RC2 Watermark for the desktop http://www.joejoe.org/forum/index.php?showtopic=1527&st=0
There on the second page.
Thanks fr this addon m8. And I would like to see that modded theme, if you can share of course. :thumbsup:
  • 3 months later...
Hey,
If I remove the following from LSPatch.inf:
[Patch.AddShortcut]Name	  =LS PatchCmdLine   =16422,"%PATCH_DIR%",LSPatch_1.1.exeSubDir	=UtilitiesWorkingDir=16422,"%PATCH_DIR%"InfoTip   =Hide or Restore Logoff/Shutdown text ~ by Windows X[Strings]PATCH_DIR="Utilities\LS Patch"
Will that mean no start-menu entry is created?
Also, how would I go about re-packing the cab with my modified LSPatch.inf?
Does LSPatch apply itself automatically or will I need to run it everytime I log on? What about newly created users, if it is automated, will it work for them too?
laze.
Edited by just_laze
Im not using msstyles themes anymore... Im usin Windowblinds 5.1 enhanced and im going to try and make and release a addon for it and NO, you cant add those buttons to any .theme unless you know what you are doing
  yadzil said:
This not working to me. The text still there after i intsall ithis addon. can u help me rick?
It will not remove the text automatically just by integrating it... It integrates a Program. You have to remove it yourself by going to the Shortcut to the app in Utilities and execute the patcher.
I installed the patch and now my computer refuses to boot up. It takes me to the logon screen, lets me log on, shows me the wallpaper and then freezes...no desktop icons, no system tray, no start menu...nothing. I dont know how to restore the explorer.exe file since it's not letting me start up at all. Any help is appreciated.
  • 3 months later...
  Quote
I had the same issue earlier this year :( (no-English computer "FR") ...I know it's a little late for "dontpanic" but I post the answer anyway, because it could be useful for other users...
launch the Task Manager, press Ctrl + Alt + Delete simultaneously on your keyboard
click on "file".. and click "new task"
now browse to the LS patch and launch it again
drag the window because it probably hide the pop-up message
in this pop-up message (..bla bla.. the text in ..bla bla..) just click "yes"
now you should be back to normal !
Scrat
