RenameMaster 2.9.1.0
What's NEW
Fix: updated the intelligent number sorting to work with very large numbers
Fix: running the new script format in batch mode didn't work
Fix: some script operations only partially saved
Fix: CTRL+A/D updated to be the same as using
File>Edit>Check/Uncheck
New: Enable/Disable button for each script step
New: added ?temp? variable option to Remove Characters/Substring options
Information: Info
Version: 2.9.1.0
Updated: October 25, 2008
Shortcut created in: All Programs\Accessories\AddOn Tools\
SendTo Shortcut: Yes
Uninstallable: Yes
Credit: *Reaper*
MD5: D6271B7574E1A7343EF5C6CBCE31D5E3
Enjoy!
Edited by *Reaper*
  • 4 months later...
