Posted March 20, 200817 yr Ragazzi ecco come True AddOn anche Windows Live Messenger 9 ITA, ragazzi questo addon prima di installare il Live Messenger, rimuove automaticamente il Messenger v4.7.0.3001, addon si integra sia con nLite sia con RVMi, ecco il likOnePiece_Windows_Live_Messenger_9_v14.0.8064.0206_True_AddOn_ITA_ Aggiornato (23 Marzo) Aggiornato (23 Marzo) Aggiornato (23 Marzo) Aggiornato (23 Marzo) Aggiornato (23 Marzo)Hash MD5 480701BE3A4F83A415BE61A7F059004BFilesize: 19,0 MB (19936533 byte)Cosa Include:DW20 (Segnalazione errori applicazioni Microsoft)Contacts (Windows Live Communications Platform)SegoeUI (Segoe UI Font)LiveCall (Windows Live Call)WLLogin (Assistente per laccesso a Windows Live)ChoiceGuard (Choice Guard command line interface)Messenger (Windows Live Messenger)RichUpload (Strumento di caricamento di Windows Live)I put here the link of the addon ENU, with my English (and that the reason why not, or open a new topic for this addon) can not give you support as you need, so please do not posted in this topic about this addon, thanks.OnePiece_Windows_Live_Messenger_9_v14.0.8064.0206_True_AddOn_ENU_ Update (23 March 2009) Update (23 March 2009) Update (23 March 2009) Update (23 March 2009) Update (23 March 2009)Hash MD5 C07A8127208F1D2BCDA6342582D1380BFilesize: 18,8 MB (19810598 byte) Edited November 2, 201212 yr by OnePiece
September 2, 200816 yr Your work is great but what about english version???This is an Italian section of the forum. If you want an English version, you should request it in this forum:http://www.wincert.net/forum/index.php?showforum=106
November 29, 200816 yr Author il link messenger 9 non funge grazie. e complimenti di tuttoLink messo a posto, anzi con questo caso gi Edited November 29, 200816 yr by OnePiece
January 11, 200916 yr Author Ragazzi da 3 giorni sto lavorando in messenger 9 per fare in true addon, o gi Edited January 11, 200916 yr by OnePiece
January 28, 200916 yr Author Ciao VegetaSSJ5, Hmmmm e un addon da fare, ma serve tempo, sono ancora molto occupato su altri cose (sul update pack sto guardando certi cose), non lo so adesso quando potr
February 16, 200916 yr Author Ragazzi addon gia aggiornato, Messenger e passato alla versionev14.0.8064.0206, aggiunto dentro addon anche il RichUpload.Ciao a tutti Edited February 16, 200916 yr by OnePiece
September 16, 200915 yr potrebbe fare una versione in spagnolo? :sweatingbullets: OnePiece essere possibile? e un'altra cosa, si potrebbe fare un addon vero come questo, ma Windows Live Mail? :icon_cool: questo
September 17, 200915 yr Author Ciao zookey, Grazie per i complimenti, ehhhh meglio di Ricks (Ricks e molto bravo in quello che fa , Secondo me Ricks e il più bravo di tutti AddOn Maker, almeno di tutti quelli che conosco io o che o visto io fin adesso ), Ricks a buttato ormai tutto il tempo in Update Pack Latino e mi sa per questa volta in mancanza di tempo a scelto usare il Svcpack Mod per questo addon (del resto Ricks a tutto in True Mod ), comunque il risultato finale e lo stesso sia usando il Svcpack AddOn sia usando il True AddOn, perché Ricks a modificato bene il suo setup.msi, e per questa ragione anche in cd più o meno tutti i due addon occupano lo stesso spazio, Riguardo Messenger AddOn Spagnolo in True Mod si certo che si potrà fare, ma non ti posso promettere niente, perché io da me come vedi gia nemmeno o trovato il tempo aggiornare il addon esistente, questo perché anche io come Ricks mi prendano molto tempo i Update pack, o perso quasi 8 Giorni per chiudere le release di questo messe (visto che o da fare il pack di WinXP Win2K e Win2k3), cosi come detto prima non ti posso promettere niente, ma se riesco trovare tempo proverò fare il addon anche in SpagnoloRiguardo Windows Live Mail, eh sai anche in comunità ITA me lo hanno chiesto da tempo, ma ecco per le ragioni che ti o detto di sopra non sono riuscito farlo, e una cosa da fare, ma anche io da me non lo so quando potrò trovare il tempo e la concertazione per farlo hmmmmmmmmmm.Ciao. Edited September 17, 200915 yr by OnePiece
September 17, 200915 yr OK, non lo sapeva e ha chiesto live mail, non tratta il lavoro di Rick, che integra il addon come un complemento a Windows, e mi piace l'idea che questo in aggiunta guidata componenti di Windows, pi
October 9, 200915 yr Can you add support for making Addon via your addon maker TOOL, Live Messenger is very cool, but i want it in my language :thumbsup_anim:
April 30, 201014 yr Il link per l'italiano non funziona ..........una domanda. Questo addon è già contenuto nel OnePiece Windows XP Post-SP3 Update Pack? Edited April 30, 201014 yr by dovdo
July 12, 201014 yr New version 14.0.8117.0416 is out. I think its last version of Windows Live Essentials Wave 3 for XP.
July 12, 201014 yr Author Hi George King, I've been a bit busy, and still are, just find the free time, I will update the addon.Ciao.
July 13, 201014 yr No problem I build for me SVCPACK Addon for all LIVE things -> Latest Windows Live Essentials and Games for Windows Live. But i think, we can start work on TRUE of Windows Live Essentials for Update Pack, because its latest (final) version for XP.
July 13, 201014 yr No problem I build for me SVCPACK Addon for all LIVE things -> Latest Windows Live Essentials and Games for Windows Live. But i think, we can start work on TRUE of Windows Live Essentials for Update Pack, because its latest (final) version for XP.well you want to make it for all essential ?that would be one big addon the reason i like the svcpack version cause of the size cab doesn't compress that high as 7zbut i think i should give it a try and also try to make a new addon
July 13, 201014 yr well you want to make it for all essential ?that would be one big addon the reason i like the svcpack version cause of the size cab doesn't compress that high as 7zbut i think i should give it a try and also try to make a new addonYes, for all Essentials, I want to have it in True mode. Yes size will be bigger...
