v5 LogCMDOpen v2.0.3.0Unlocker v1.9.0Notepad2 v4.1.24.0
Contents:
CabTool v1.8
ClearType turned on by default
Microsoft Calculator Plus v1.0 (Replaces calc.exe)
Microsoft Image Resizer PowerToy v7.0.224.0
Microsoft Makecab v6.1.7600.16385 (Win7 final version)
NotePad2 v4.1.24.0
Quicklaunch is now enabled by default.
Unlocker v1.9.0
tskill v5.1.2600.0 (Needed for the uninstall routines on none XP pro systems.)
SHELL EXTENSIONS:
.dll/.ocx/.ax Register/Unregister Regtweak
.inf advanced install\uninstall Regtweak
Back v3
Context Attributes
Copyto\Moveto Regtweak
File Extension Toggle v3
Find Target v3
HashCheck v2.1.11.1
Hidden Files Toggle v3
Mainsoft ClipName v1.2.7
ModifyPE
NinoTech Date Edit v4.0
Open cmd Here v2.0.3.0
Open folder in new window Regtweak
Select All v2
Synesis Run with arguments... v2.0.2.32
Synesis File Case v2.0.2.31
...and a custom Power Menu to contain most of the shell extensions
Size - 1.69 megs MD5Hash = d41e5683789e3b1b4d569d5e034b411d
SpiritPyres 4 extensions (Back, Hidden Files Toggle, File extensions Toggle and Select all) Can be customized through the following registry file:
Windows Registry Editor Version 5.00[HKEY_CURRENT_USER\Software\SpiritPyre Extensions]Refresh Key=e[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\BrowserBack]@=&Back[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\FileExtToggle]@=&File Extension Toggle[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\HiddenFilesToggle]@=&Hidden Files Toggle[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\SelectAll]@=&Select All
Just Change the titles to whatever you want and then apply!
  • 7 months later...
Kels, a request for this pack and others that might be setting file associations for notepad2:
How about separating the reg entries that set file associations for notepad2 into their own [notepad2.fileassoc.reg] entry section. It would make it a hair (lots!) easier to edit the .inf without further bothering you for customized versions.
And hey, thanks!
  • 4 months later...
  • 4 months later...
