New in version v16.2!
Special UberPacK Software Uninstall menu: (Click Show Updates to see it)
v16.2 Log:
Unlocker v1.9.1
VistaSwitcher v1.1.4
NirCMD v2.65
Full list of things that are included.
Main Additions
ClearType turned on by default
Compumatrix WallPaper Changer v2.1
Microsoft Calculator Plus v1.0 (Replaces calc.exe)
Microsoft HighMAT CD Writing Wizard (KB831240)
Microsoft Image Resizer PowerToy v7.0.224.0
Microsoft Makecab v6.0.6001.22192 (Vista SP2 final version)
Microsoft OpenType\TrueType Font Properties Extension v2.30
Nirsoft NirCmd v2.65
Quicklaunch is now enabled by default.
Recycle bin start menu option.
RefreshEM
RegShot v2.0.1.70 Unicode (Uninstallable)
Replacer v2.63
Service Tweaker v1 <-- Requires .NET Framework!
VistaSwitcher v1.1.4 (uninstallable)
Unlocker v1.9.1(Includes Unlocker Assistant and is uninstallable)
TSkill 5.1.2600.0
WhyReboot v1.0.1.537
Xpero's EXPander v1.5 Final <-- Requires .NET Framework!
Xpero's RegFile Merger v1.0b <-- Requires .NET Framework!
SendTo Menu Additions
7zSplit
CabTool v1.8
FGCBA v0.897
HotFix Extractor v1.01 From Sereby of RyanVM's forums
ISO Creator
Reg2exe v2.25
Reg2Inf v0.46
Resource Hacker v3.5.2b
Shell Extensions
.dll/.ocx/.ax Register/Unregister Regtweak
Advanced .inf install/uninstall Regtweak
Attribute Changer v6.20 (Uninstallable)
Back v3
Copy To/Move To
File Extension Toggle v3
Find Target v3
HashCheck v2.1.11.0(Uninstallable)
Hidden Files Toggle v3
Mainsoft ClipName v1.2.7
ModifyPE
Open CMD Promt v2.0.2.1 (Uninstallable)
Open in a new window
Run with arguments v2.6.0.2
Select All v3
Synesis File Case v2.0.2.31
WIAAutSDK v2
...and a custom Power Menu to contain most of the shell extensions
Size - 5.46 megs
Hash = File: Kels_Uber_Addon_v16.2.rar
CRC-32: 694d82b1
MD4: 89bfe2d888bd1902d612da206f81437c
MD5: f27291584823b21e6128cb5936c5f575
SHA-1: d6201a2b7478a0f2a2549cccc279012f3479c18c
I must thank RyanVM, Xable, Skitty, Dgelwins, Zacam, booogy, Joey Joe, Mrs. Peel, Mindwarper and Siginet for this pack. (And any others I forgot to mention, Thank you!) I got it by adding Ryans Addons pack and all of the non-conflicting fan made Addons into one large pack. I will be updating this pack as often as I find something new to add or if I am notified of an update to the programs included...
SpiritPyres 4 extensions (Back, Hidden Files Toggle, File extensions Toggle and Select all) Can be customized through the following registry file:
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions]
Refresh Key=e
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\BrowserBack]
@=&Back
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\FileExtToggle]
@=&File Extension Toggle
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\HiddenFilesToggle]
@=&Hidden Files Toggle
[HKEY_CURRENT_USER\Software\SpiritPyre Extensions\SelectAll]
@=&Select All
Just Change the titles to whatever you want and then apply!
I do not, will not, nor want to support a cracked WGA version anymore...
I stopped that LONG ago. (like 3+ years ago)
Go buy Windows.
________________________________________________________
Notepad2 v4.2.25.558!!!
Notepad2 is a FANTASTIC app, improving greatly the original Notepad shipped with Windows! Notepad2 follows the basic Notepad principle, keeping it small, fast, without frills, but it improves it greatly! Notepad2 is a fast and light-weight Notepad-like text editor with syntax highlighting.
NotePad2
Size = 366kb
Hash = File: Kels_Notepad2_v4.2.25.558_addon.rar
CRC-32: cfc23442
MD4: 0159a4056d47e60dd1940c29a1843bbb
MD5: 04d2b282b7ee70217f79285b77cc78a7
SHA-1: 7de6aa4b620719e8a36e45309a78db12e8ece097
  • Replies 497
  • Views 220.3k
  • 4 weeks later...
Hi, thx for your response. I am using v9.9.2. Today I wanted to make a new version of XP with nlite, because my Win crashed and doesn't want to work any more :). So I downloaded all new Kels addons. Last time I had the same error message with another version, unfortunately I have no elder version. Only 8.6, but with this addon, there was another error, lol. Everytime nlite crashed at the including of this addon, problems with calc.ex_. So I am not able to use this addon, worse luck. Perhaps later I will upload a screenshot, error is reproducable. I love your addons, thx for all your work.
Edited by DanielCollinet
  • 4 weeks later...
Thanks Kel, I love your uber pack. I have v10 and I am wondering how I can update my current XP installation to v10.1. :welcome:
