Posted (edited)
Thunderbird Addon Maker v0.12
post-5822-1213219831.pngUpdated 28 Jul 08
  • This is a little script that will download the current 2.0.0.x Thunderbird, in your current languange.
  • Or, will download the English version of 3.0a1 and create a localized version for you.
  • It will then insert your personal data and create an addon, placed in the current folder, that can be used in nLite or RVM.
  • A log file is created for all file copies. So you can see what was copied from your system to the addon.
  • It will insert all of the passwords, themes, plugins and extensions that you currently have installed on your system. It will disable the Profile Migrator and is completely silent.
  • Requested here.
MD5: 26E973B09DE8193FE2CA5D850C52C97E
Changelog
07-28-08
-updated links
6-11-08
-Changed the mechanism for locating the language
06-09-08
-Initial script to create addon of current 2.0.0.x 3.0x Thunderbird
Edited by N1K
Think this needs to be updated. attempt to use and wget logs says --23:05:01-- ftp://ftp-mozilla.netscape.com/pub/mozill...n32/en-US/*.exe
=> `Files/.listing' on either version 2 or 3
Also when it did work last week did not include all my folders
But Thank you for all your work including the FF addon maker !!
Made it by request and I haven't kept it up. I will update it to work like my Firefox Addon Maker as soon as I can.
just a quick update to update the links
There isn't very many people using this. If the need arises, I could make this more like my Firefox Addon Maker.
Posted (edited)
Tried to run, but get error message says
Windows cannot find "start.bat"
edit *
I just extracted exe to folder and ran go.cmd seems to have worked will test shortly
Edited by nujackk
Posted (edited)
edit *
oops - I'll repost
***EDIT***
Fixed
Edited by Jonnyboy
  • 3 months later...
Posted (edited)
Hi Jonnyboy.
This project sounds very interesting : :-D
But... the link is broken :-(
Best regards
Niko
Edited by Niko
  • 7 months later...
  • 4 weeks later...
