Posted September 18, 200816 yr Windows Search 4.0 (KB940157 ENU XP Sp3)Info: Windows Search 4.0 is an updated component of Windows that enables instant search on your computer.WS4 lets you perform an instant search of your computer. WS4 helps you find and preview documents, e-mail messages, music files, photos, and other items on the computer. Please refer to the Knowledge base article KB940157 for a full description of the technology. +MD5: c28e13bfc14dc768c3f88125aa797c83Size: 2.93 MBWhats NEW!!!- Now updated with NEWER search engine and search filters from Vista SP2- For compatibility reasons Entries_*.ini will prevent you from removing 'Terminal Services', 'Network Provisioning' & 'MSMail and MAPI' components if you are using it with nLite (you dont need to but I recommend you keep 'Search Assistant')- Addon/UpdatePack makers are welcome to modify/improve/translate/release this addon for use with your language (including English) all I ask is a honorable mention - Program can now be (un)installed via Add Remove Windows Components- Can also be turned off during unattended setup by adding the following to the Components secion WINNT.SIF[Components]WDSearch=Off- Plus other improvements...Changelog:Jul 11-11- Fixed text document preview/indexing (tquery.dll)- Couple other iFilter fixesJul 5-11- Updated with Vista SP2 search engine & filtes (replaces KB915800-v4 and KB961184)- Program can be uninstalled via Add/Remove Windows Components- Addon is now compatible with both nLite and RVMiJun 10-09- Added KB961184 and KB963093Sep 20-08- Tweaked INF a bit- Added [NeededComponents] to both entries.ini to stop nLite users from removing necessary stuff- RyanVM Integrator compatible version added (thanks to yumeyao)
September 18, 200816 yr thx for this addon its a quite a good tool and a helpfull one downloading and testingthx
September 19, 200816 yr Author Addon/UpdatePack makers are welcome to modify/improve/translate/release this addon for use with your language (including english) all I ask is a honorable mention MrNxDmX will probably soon have a turkish version
September 19, 200816 yr MUI can found here:http://support.microsoft.com/kb/94015730 languages includehttp://www.microsoft.com/downloads/details...;displaylang=en Edited September 19, 200816 yr by AndreyPopov
September 20, 200816 yr Author Sep 20-08- Tweaked INF a bit- Added [NeededComponents] to entries.ini to stop nLite users from removing necessary stuff- RyanVM Integrator compatible version added (thanks to yumeyao)
September 22, 200816 yr @ RicksDo U know how to unpack & repack an autoextractible CAB archive (NETSETUP.exe in I386) ? I need to patch some files inside with batch script like your V'ISO.Thanks.
September 22, 200816 yr well that something i might help you in i have this tool i found couple of monthes ago while i was searching for a way to make inf setupshttp://www.inner-smile.com/dl_inf.htmthe free version of it makes normal inf the pro makes an exe files sadly i didn't test the pro version i hope i could have helped edit: lol while i was typing this replay i found another way that might help you can use a built in utility in windows xp <<<dont know if its in vista go to run and type this command iexpress i hope i helped Edited September 22, 200816 yr by Dark_Knight
June 9, 200915 yr I noticed there a new high-priority security update for Windows Search. Is this something that you are able/willing to incorporate into your addon?Here's a link for the info on the update: Vulnerability in Windows Search Could Allow Information Disclosure (963093)Thanks, again, Ricktendo for this update. :thumbsup_anim: Uncle Gadget Edited June 9, 200915 yr by Uncle_Gadget
June 11, 200915 yr Author This addon was only meant to show that it could be done, you should be using a UpdatePack that includes this programAnyway updated addon with KB961184 and KB963093 same filename different hash
June 11, 200915 yr This addon was only meant to show that it could be done, you should be using a UpdatePack that includes this programThanks for the quick update! :worthy: Just curious, though, is there a particular reason you recommend this be in the update pack? The only pack I'm aware of that includes it is OnePiece's - and his has FAR TOO MUCH stuff in there for me. Captain Gadget
June 11, 200915 yr Author Just curious, though, is there a particular reason you recommend this be in the update pack?No, no good reasonBTW what version do you use, RMVM or nLite?
June 12, 200915 yr BTW what version do you use, RMVM or nLite?I use RVM to integrate the update pack, IE8, and .Net Framework, but I use nLite for all addons (Including your Search addon) and Windows tweaks. Thanks again! Edited March 15, 201015 yr by Uncle_Gadget
July 12, 200915 yr Hello ricktendo64, excellent work to you, helps a lot =]My name is Vitor, I'm from Brazil, I need help from youI need the Windows Search 4.0 for Windows XP PTB, not ENUIf possible of course to this addon, I will be gratefulLink download Windows Search 4.0 PTB for Windows XP :http://www.microsoft.com/downloads/details...a3-5b98904f7cdaThanks^^(Thanks Google Translate, my English is terrible =,[ )
December 24, 200915 yr HI,newbie here.first link does not seem to be going anywhere.i know i am year or so late,anybody has other download link?RVMi preferred.thank you
April 17, 201113 yr It's been almost an year, and no news. The download links aren't working. Will you please update?
April 21, 201113 yr If I get some time, the addon need a complete reworkCan you give an ETA, please? Also, it would be great if you will post the addon to ryanvm forum. Thank you very much.
