Jonnyboy Posted September 27, 2008 Posted September 27, 2008 (edited) Inf Assistant v0.23Updated 6 Dec 08Features: This is an hta script that will create a "True" addon It can locate an unlimited number of folders and an unlimited number of individual files, as needed It can add an unlimited number of ProfileItmes(shortcuts) It works in temp folder and puts completed addon in your current location It renames every file to comply with 8.3 or can rename only the filename and leave the first 3 characters of the extension It parses the filepath and and inserts most of the DIRID's (16423, 16389, 16410, 16412, 16418, 16416, 16405, 16417, 16384, 16400, 16390, 16403, 16411, 16393, 16392, 16432, 16391, 16386, 16395, 16424, 16419, 16409, 16415, 16408, 16407, 16406, 16422, 16404, 16421, 16425, 16420, 17, 24).Options: Can edit the String Variables Can copy inf to clipboard and edit as you like, then complete the addon on your own. Can add your registry settings Can add a pre-built uninstaller, that will uninstall completelyNotes: This is a work in progress. I intend to add the ability to rename all files as you like, or 8.3 and keep the existing extension so long as meets 8.3. I intend to add the ability to insert additional String Variables and integrate them into the inf I hope to be able to allow edit of the the inf on the fly and continue with addon I hope to add a timer and status bar along the bottom of hta I hope the add the ability to resize elements when resizing main page I am open to suggestions for further featuresCompatibility: Tested in Windows XP and Vista Not tested in 64-bit systemsObstacles: Will not process any folder that you do not have permission to Read, will cause errorMD5: 42F7AD8202196DF7D606F9D09D103C82Size: 378 KBChangelog:12-6-08 - v0.23-resized initial screen to 800x480-fixed bug where Delete ProfileItems may insert wrong path-resized screen-moved copy files to create addon-added color to inf for easier reading-added option for renaming file names while leaving the extension the first 3 characters of the extension-moved strings to separate page, instead of popup-moved profileitems to a separate page-added a few status messages-added ability to have spaves in strings, in situations where spaces in strings are not permitted, the spaces are replaced with "_"-made check boxes on main page look and act like buttons-renamed string variables to be easier to recognize and understand-fixed bug where Deldirs and Delfiles were not printing-fixed typos12-2-08 - v0.22-fixed bug where AddReg=prog.addreg and [Prog.AddReg] would not display if not adding registry entries12-1-08 - v0.21-added Vista compatibility, must register\unregister safrcdlg.dll each time you add individual file -added ability to add ProfileItems-added DIRID's(16423, 16389, 16410, 16412, 16418, 16416, 16405, 16417, 16384, 16400, 16390, 16403, 16411, 16393, 16392, 16432, 16391, 16386, 16395, 16424, 16419, 16409, 16415, 16408, 16407, 16406, 16422, 16404, 16421, 16425, 16420, 17, 24).-added ability to add regstry entries-changed uninstaller to optional entry-fixed bug with renaming files incorrectly11-16-08 - v0.20-rewrote using hta as front-end for vbscriptv0.14-fixed bug where filenames with "~" in filename would not copy when creating cab-fixed bug where filenames with "&" in filename would not add to CopyFilesSection.infv0.13-added script to identify filenames that were locked or in use when creating the cab file-fixed bug when using "On-the Fly" file rename of individual filesv0.12-added script to allow "On-the-Fly" file renaming for duplicate files when not using Rename All Files-fixed bug with multiple folders not copying properlyv0.11-fixed bug with renaming files when selected not to-fixed bug with adding single file not copying to cab filev0.1initial posting Edited December 7, 2008 by Jonnyboy Quote
Guest Posted September 27, 2008 Posted September 27, 2008 that something i have to see thx for the tool and downloading to test it Quote
Jonnyboy Posted September 27, 2008 Author Posted September 27, 2008 Great toolthanks - it's a work in progress Quote
*Reaper* Posted September 27, 2008 Posted September 27, 2008 Outstanding work Jonnyboy!I was working on a addon that had 2,338 files in it....Many of which had the same name.....Tons and tons of renaming and such.....Been working on it for much longer than I care to admit......With this tool.... Took less than 10 min to complete the inf...... :worthy: Thanks for such a GREAT tool...... :beerchug: Quote
Jonnyboy Posted September 27, 2008 Author Posted September 27, 2008 Outstanding work Jonnyboy!I was working on a addon that had 2,338 files in it....Many of which had the same name.....Tons and tons of renaming and such.....Been working on it for much longer than I care to admit......With this tool.... Took less than 10 min to complete the inf...... :worthy: Thanks for such a GREAT tool...... :beerchug:Glad it helped!That is exactly the purpose for the little script. Quote
Jonnyboy Posted September 27, 2008 Author Posted September 27, 2008 updated to v0.12Changelog:v0.12-added script to allow "On-the-Fly" file renaming for duplicate files when not using Rename All Files-fixed bug with multiple folders not copying properly Quote
Guest Posted September 27, 2008 Posted September 27, 2008 Wow thanks Jonnyboy i like this tool :beerchug: :giveheart: :throb: Quote
Jonnyboy Posted September 27, 2008 Author Posted September 27, 2008 (edited) that something i have to see thx for the tool and downloading to test itExcellent tool Jonnyboy Wow thanks Jonnyboy i like this tool :beerchug: :giveheart: :throb:Glad you all like it! Edited September 27, 2008 by Jonnyboy Quote
orbit30 Posted September 27, 2008 Posted September 27, 2008 Man i absolutely love this tool, you sir are a star... Quote
shahed Posted September 27, 2008 Posted September 27, 2008 (edited) Awesome tool, just what i was looking for to make my inf writing/editing more simpler and less time consuming.Thank you for another excellent script tool :worthy: Edited September 27, 2008 by shahed Quote
Jonnyboy Posted September 27, 2008 Author Posted September 27, 2008 Awesome tool, just what i was looking for to make my inf writing/editing more simpler and less time consuming.Thank you for another excellent script tool :worthy:Thanks, glad you like it. Quote
Gorki Posted September 28, 2008 Posted September 28, 2008 Mate I have no words to say THANK YOU! :worthy: Awesome work! :thumbsup_anim: Quote
Jonnyboy Posted September 28, 2008 Author Posted September 28, 2008 Mate I have no words to say THANK YOU! :worthy: Awesome work! :thumbsup_anim:If you use it, that's enough for me. Glad you like it! Quote
NIM Posted September 28, 2008 Posted September 28, 2008 Thx Jonnyboy, already first result on google :prop: http://www.google.hr/search?hl=hr&clie...ant&spell=1 Quote
Jonnyboy Posted September 28, 2008 Author Posted September 28, 2008 Thx Jonnyboy, already first result on google :prop: http://www.google.hr/search?hl=hr&clie...ant&spell=1WOW! How did that happen? Quote
Gorki Posted September 29, 2008 Posted September 29, 2008 (edited) Works great, saves toooo much time and trouble in just several mouse clicks. :beerchug: ...[*] Files that are in use, will not copy when making the cab file, but the file will be included in the file lists...This is interesting. Is it possible to override this somehow,or even make some kind of note when making cab so user would be aware on which file to consider for further work with? P.S. I noticed you still have v.011 in title bar... Edited September 29, 2008 by Gorki Quote
Jonnyboy Posted September 29, 2008 Author Posted September 29, 2008 Works great, saves toooo much time and trouble in just several mouse clicks. :beerchug: This is interesting. Is it possible to override this somehow,or even make some kind of note when making cab so user would be aware on which file to consider for further work with? P.S. I noticed you still have v.011 in title bar... I have posted with correct version.I will test some scripts to validate the filenames and check that each filename in indeed in the cab. When I get it right, I'll post an update. I've had a few days off, back to work tomorrow (6 days a week 14 hour days). But, I'll try to get some done on it. Quote
Jonnyboy Posted September 29, 2008 Author Posted September 29, 2008 As it turns out. It was easier than expected.Updated to v0.13Changelog:v0.13-added script to identify filenames that were locked or in use when creating the cab file-fixed bug when using "On-the Fly" file rename of individual files Quote
NIM Posted September 29, 2008 Posted September 29, 2008 WOW! How did that happen? Google is crawling our pages pretty fast Quote
Jonnyboy Posted September 30, 2008 Author Posted September 30, 2008 update postedChangelog:v0.14-fixed bug where filenames with "~" in filename would not copy when creating cab-fixed bug where filenames with "&" in filename would not add to CopyFilesSection.inf Quote
Gorki Posted September 30, 2008 Posted September 30, 2008 Now that was fast update. I add my vote! Thanks... :thumbsup: Quote
Guest Posted September 30, 2008 Posted September 30, 2008 (edited) Thanks for update in 0.13to0.14 is very fast updater and thanks for polled that is Godsend tool it meant is very good and best tool because it s usefull tool :hug: :guitar: :throb: Edited September 30, 2008 by mona Quote
