Secret Maryo Chronicles
Information: Info
Version: 1.9
Addon Release Date: Sept. 15, 2009
Shortcut created in: All Programs\Games
Uninstallable: Yes
Credit: *Reaper*
What's new in Version 1.9
X implemented animation management
X new sprites : rotated sign, cloud block, sand block and slime block
X new enemy : spikeball ( graphics from yoshis_fan )
X new ice_kill, iceball, mushroom_blue sound ( from evans.jahja )
X furball, flyon, gee, krush, turtle and turtle boss moving state handling updated
X gee, krush, turtle and turtle boss movement handling updated
X implemented ability to reset the options
X implemented path rewind move type
X added metal spike and desert block static enemy to the editor
X added spanish translation ( thanks lightbuster )
X 3 level updates ( from sauer2 )
X updated level yuki2000 ( thanks konstantin )
X updated scaley ( from levelengine )
X added spikeball to world 3 and 4 ( from guest_xd )
X added editor mouse auto hide to the options
X spika and running shell both get hit on collision
X leaving level settings with a different music filename plays the new music
X entering level settings does not fade out the music anymore
X updated translations
X SHIFT + CTRL + A does now deselect everything
X shell does not die anymore if it hits a box from below
X fire resistant and ice resistance options added to static enemy
X updated mouse collision handling
X updated hud time calculation
X updated opengl version warning
X updated font
* fixed linked turtle shell does not handle collisions
* fixed path position can not be edited if it is a floating point value
* fixed massivetype change is set to not valid object types if multiple objects are selected
* updated french translation ( from thebosssdu68 and sst )
* fixed loading world with no waypoints crashes
* fixed active text box does not handle direction keys
* fixed crash when changing flyon, eato or thromp image directory
* fixed music is not looped in certain event situations
* fixed dying because of the fixed camera velocity in custom level mode results in a endless loop
* removed high frequency noise from death_box (thanks evans.jahja)
* fixed ghost maryo with ice power throws fireballs
* fixed world without objects can not be entered
* fixed changing flyon direction in the editor does not update velocity
* fixed shell y velocity was not reset when hitting a massive object on top/bottom
* fixed gee with no fly distance always flies
* fixed flyon can not get hit if frozen and gee only from top
* preload more images
* update string to float conversion function to work correctly
* fixed semi massive text box does not activate
* disabling the global effect clears the active particles
* use new boost filesystem path handling functions
* fixed lvl_4 camera limit ( thanks guest_xd )
* updated ghost window_1 settings ( thanks yoshis_fan )
* plugged rare memory leaks
* 2 small level updates
* some level fixes ( thanks guest_xd )
* many cleanups
* removed fuzzy and unused translation text
NOTE:
This also has the HIGH quality music addon included.
tabdownload.pngPart 1
tabdownload.pngPart 2
MD5: df54b38f26115beb14881aefc90988ac
Enjoy!
Edited by *Reaper*
Sweet..this will do nice in free time... maybe I even show it to my younger cousin,I hope I could remove him latter when he starts playing it...LOL :D
thanks Gorki :thumbsup_anim:
I've got another game addon I've done.....
Not sure if I should post it or not.....
Its open source also.....
Alien Arena 2008.....
http://icculus.org/alienarena/rpa/index.html
If you like Quake like games... You will love this one....(At least I do)
Only drawback... Its huge.... The addon is 202 mb.....
Don't know if anyone would be interested or not.....
If anyone wants it.... Just let me know and I'll post it.....
Actually that game look very cool, ut would be nice to see it as addon, however 202mb is not small size (to upload)...so it's up to you to decide...
Anyway...this one is nice. :)
How'd you manage to disable the embedded toolbar installer? I wrestled with it then gave up and wrote a .bat uninstaller that ran immediately after install to get rid of it. Not very elegant.
games addons, sounds really cool, maybe those vista games ported to xp fit in this forum too,great addon!
:nostalgia:
If you are referring to standard MS games (Solitare,Minesweeper,...) made for Vista and ported to XP that was already done way back. Check this sticky. ;)
Thanks Reaper :thumbsup_anim:
  • 4 months later...
  • 4 weeks later...
  • 3 months later...
