AI Roboform v6.9.98
tabdownload.png International INF
MD5: 66c0965381dfe5cd2130059f61be1f8f
Website: http://www.roboform.com/
Passcards_fetcher_for ricks_AIRoboForm_Addon.rar \ 3063F1912BA42346588743ED5C2CD4BF
Changelog:
Dec-21-09
- Updated v6.9.98
- Localized shortcuts (exept Chinese, Japanese and Turkish)
Aug-9-09
- Updated v6.9.97
Jul-28-09
- Updated v6.9.96
Jul-7-09
- Updated v6.9.95
Apr-1-09
- Updated v6.9.94
Mar-18-09
- Updated v6.9.93
Dec-26-08
- Updated v6.9.92
Sep-25-08
- Updated v6.9.91
- Slimmed down INF International [strings]
June-27-08
- Updated v6.9.90
- Added INF support for the following languages: Chinese, Dutch, French, German, Italian, Japanese, Spanish, Turkish
May-30-08
- Updated v6.9.89
Mar-8-08
- Updated v6.9.88
- User can now set preferred language
Jan-21-08
- Updated v6.9.87
Dec-1-07
- Updated v6.9.85
- Firefox Extension is installed by default
Nov-26-07
- Updated v6.9.84
Sep-28-07
- Updated v6.9.82
Sep-22-07
- Updated v6.9.8
July-23-07
- Updated v6.9.5
July-17-07
- Updated v6.9.4
Other Info:
Here is how you set the addon to use your preferred language (default is en-english)
- Open RoboForm.inf in any text editor
- Scroll/look for the [strings] section and edit NAME, EMAIL and LANG (optional)
; U s e r O p t i o n a l
NAME =""
EMAIL=""
URL ="http://www.wincert.net"
LANG ="en-english"
; O t h e r L a n g u a g e s
; ar-Arabic
; bla, bla...
Posted (edited)
YEP!!! Ive been using it for LOOOOOONG... Password protect your Data, easy to use you can even Back Up your Logins and passwords and next time your reinstall you can Replace them.
Edited by ricktendo64
  • 7 months later...
  • 4 weeks later...
Hello, I am French, I think what you do very well
No, but I use it rvm
I would like to know how to add a hand roboform
Best regards
sorry for my English, I translated with google translation
Mar-8-08
- Updated v6.9.88
Other Info:
NAME =""
EMAIL=""
LANG ="en-english"
; ar-Arabic
; bla, bla...
Posted (edited)
Thanks Ricks
new version available
Changes in Version 6.9.89:
* Add support for Firefox 3.0 RC1.
* Fix Unload Portable in IE Protected Mode on Vista.
* Fix Logoff on User Switch on Vista.
* Fix 'RoboForm did not fill any form fields' message during Pro activation.
* Fix decoding of some Japanese URLs.
* Add warning about Skype IE Addon that causes problems in RF Pro activation and general browsing.
* Fix RoboForm2Go disconnect from browser sequence, it could cause freezes.
* Fix Matching Passcards mini-dialog takes focus when uses mouses over it.
* Fix error in mousing over identity protected by dual password.
* When doing Copy Home, offer to overwrite or rename if such identity already exists.
* Add Turkish localization.
* Firefox: RF should not connect to Google sidebar.
* Firefox: RF should not attach to Firefox Master Password dialog.
* Firefox: discontinue use for rfmozhlp.dll because FF 3 crashes on it.
Homepage - http://www.roboform.com
Edited by Dziubek
If you were brave enough you could add them to the cab and list them under
[MyDoc.Files]
cache.rfo
license.rfo
options.rfo
RoboFormDataHere.txt
Don't forget to also list them under [sourceDisksFiles] with a =1 to tell the INF they are in the cab
[SourceDisksFiles]
ExampleNew.files=1
Posted (edited)
thanks rick, made a small Pass Card fetcher for you're addon, it works! :D
; integrate this one time and it will create a separate addon next to 1386 @ the root
; that will be the addon containing you're pass cards but you will need Ricks AI RoboForm addon to be integrated or integrate both at once
; this works with rvm integrator only!
Edited by ENU_user
Changes in Version 6.9.90:
* Add support for Firefox 3.0 official release, final touches.
* Implemented Activate Pro on Install capability.
* Fix sizing of controls in manual Save dialog.
* FF 3: fixed bug in localized context menus.
* FF 3: removed support for Firefox 3 betas.
* Added Enterprise policies.
