AMIRZ Posted October 19, 2008 Posted October 19, 2008 (edited) Vista Ultimate Extra : Glass, Pearl, And Tinker Sounds For XP Hello everybody. This is the sounds installer from the new Vista Ultimate Glass, Pearl, and Tinker Sound scheme's.To install just double click "media.exe" and it will install the wav's intoC:\Windows\Media by default, then go into your sound Properties and changethe defaults to use the new ones you just installed. (You can also manually unzip it by using WinZip etc as usual).*NOTE* this can also be used on any version of Windows: 98, ME, 2000, Xp, 2003, and all Vista versionsCredits to metalrob169 and toon22 for this. Thx alot mate - Download Vista Ultimate Glass, Pearl, And Tinker Sounds For XP (All Windows: 98, ME, 2000, Xp, 2003, and all Vista versions):MD5: D7FAB293D3060ED53EB76D0463B95B73 , 12,48 Mb:http://www.4shared.com/file/67526011/33482...nds_For_XP.htmlCya! Edited October 19, 2008 by AMIRZ Quote
Mr_Smartepants Posted October 28, 2008 Posted October 28, 2008 (edited) Any way to make this automated/unattended? With 'sound schemes'? Kind of like Ricktendo64's .inf method wrapped with a switchless installer. I don't know which registry entries to export for the sound scheme mapping.In Vista, these are placed in:%windir%\Media\Schemes\Glass%windir%\Media\Schemes\Pearl%windir%\Media\Schemes\TinkerBug - Some of the files have double .wav extensions. (ie. Vista-Glass_tada.wav.wav) Edited October 28, 2008 by Mr_Smartepants Quote
AMIRZ Posted October 28, 2008 Author Posted October 28, 2008 Any way to make this automated/unattended? With 'sound schemes'? Kind of like Ricktendo64's .inf method wrapped with a switchless installer. I don't know which registry entries to export for the sound scheme mapping.In Vista, these are placed in:%windir%\Media\Schemes\Glass%windir%\Media\Schemes\Pearl%windir%\Media\Schemes\TinkerBug - Some of the files have double .wav extensions. (ie. Vista-Glass_tada.wav.wav) You meant here? http://www.wincert.net/forum/index.php?showtopic=4640(By ricktendo64) Quote
Mr_Smartepants Posted October 28, 2008 Posted October 28, 2008 (edited) You meant here? http://www.wincert.net/forum/index.php?showtopic=4640Maybe, I'm taking a look at those.I'm already working on the registry entries needed to install these sounds. If Rick's done it already, awesome!Yeah, Rick beat me to it. I was working on installing the sounds to their own directories, then mapping the sound schemes to each one (none as default). Edited October 28, 2008 by Mr_Smartepants Quote
