Posted November 19, 200816 yr Hello guys since i notice that vista can run windows 7 Math input panel but it cant recognize ink (it will not recognize any words number or any when u write it)you will just need alky 1.1 and if you got windows 7 and have Math input panel files patch mip.exeim fixing if how can i fix the problem (not recognizing ink)my bro said (AMIRZ) maybe it has some missing component ( i dont remember what he said exactly LOL) gotta fix itif you want to try the math input panel download the attachment And then patch it with alkyMath input panelAlso vista can use this(EDITED: oops i forget the screenshot lol) Edited November 19, 200816 yr by jdd
December 1, 200816 yr :thumbsup_anim: Hello Bro Jdd, Thx alot for uploading/the link and this thread Bro'. Lol after reading the title first i thought it's already finished to work properly within Vista (or Xp) b4, but nevermind it's OK (as you said it works in Vista though without handwriting recognition, anyhow still thx). Btw you can also get real Windows 7 Calculator working properly in Vista, just check it out, Since you already have Windows 7 OS installed in your machine (i still don't, not yet) then you can check the missing Dll dependencies i.e by using Dependency Walker tool (32 bit) to determine which dlls it calls (with required APIs support calls). Or at least you can manually find them, as they are commonly in the program directories (C:/Program Files), common directory (C:\Program FIles\Common FIles), Windows Directory (C:\Windows), and System32 Directory or in the environment variables (if not in C:\ by default): %ProgramFiles%, %Windir%, %Sysdir%, etc (i.e check the matching dll name by using search tool). There might also be some "hacking" tools too to patch it (decompile) internally (i.e for OS exclussive protection/license recognition) e.g Olly Dbg.. (upps just kidding sorry not mean to break the rules here by talking about them, but seriously they can do it too). Don't forget about new .exe.mui sys binary file (resource file, based on localization etc) since it has come as new main apps UI resource in Vista and might be later/future Windows OS system binaries. Edit: :g: Mmm.. Bro, it seems you only uploaded the zipped exe, where's the exe.mui file (commonly in en-US folder in same directory). Does it exist or not? Also how about other apps (e.g Paint and Wordpad), any chance for them? And seems the MIP.exe doesn't work in my Xp (how you can make it work? Did you enter Windows 7 serial during Alky setup? Lol i dont have it). Thx BroAs i've seen your previous screenshot (where's it here Bro?) the math input panel still can't recognize your handwriting nor the mathematical expression result, but strange, the GUI still appears (Note: Vista Ultimate/Premium/Business already has inking support like previous Xp Tablet, but still not sure about Windows 7 beta, maybe it's different/new animal there and so on, who knows?). But i will try this first in Vista so thx alot for the code. PS: i will install Windows 7 next year to make some "experiment" too (still very busy, i'm just back now). Oh, one more, inspired with you, alternatively i will also upload a Replacement for Math Input Panel in Xp (and maybe Vista) here, there are some options than one, and still better than nothing at all, at least for "additional tool" in Xp. That i have also made stand alone version for new Tablet Input Panel (Tablet PC) for Xp Pro/Home/MCE (just killed my confusion), comes with installer/uninstallable, light and tweaked, without hacking or changing the OS at all (not touch any sys files). Long live Xp, good luck Bro' and Cya! =====================================================================EDIT: Hey you can download the complete files (exe and dlls) of Windows 7 Math Input Panel (MIP) M3 build 6801 for Vista/Xp here:http://www.4shared.com/file/74102192/f02b0...sta_by_Jdd.htmlYes you can run it on Vista (it can recognize inking although not perfect yet)...anyway good luck Edited April 26, 200915 yr by AMIRZ
December 1, 200816 yr Latest/Confirmation: :thumbsup_anim: Bro, I've got it! Works so well, i tried again to fix it and worked! however only inking works but the math expression/equation recognition doesnt. Seems some dll missing there, so could u upload the remaining files that i said above? :icon_cool: i'd like to help to make it really functional in both Vista and Xp, thx Bro awesome job! As the first one then you should spread this more widely! Im Ur witness, may i write too about this in WinMatrix too i will give you full credits for it. Again, thx alot Bro, U Rockn Roll! :thumbsup_anim: This is my own screenie (a real Xp, pliz see the blue taskbar)PS: To mod, this should be hot topic! Edited December 1, 200816 yr by AMIRZ
December 1, 200816 yr AMIRZ what dll files you want i can get them for you just tell my and i would try and thx for both of you in making xp get more Vista and 7 Ability
December 3, 200816 yr Author Latest/Confirmation: :thumbsup_anim: Bro, I've got it! Works so well, i tried again to fix it and worked! however only inking works but the math expression/equation recognition doesnt. Seems some dll missing there, so could u upload the remaining files that i said above? :icon_cool: i'd like to help to make it really functional in both Vista and Xp, thx Bro awesome job! As the first one then you should spread this more widely! Im Ur witness, may i write too about this in WinMatrix too i will give you full credits for it. Again, thx alot Bro, U Rockn Roll! :thumbsup_anim: This is my own screenie (a real Xp, pliz see the blue taskbar)PS: To mod, this should be hot topic!thats what im saying it has a prob like thatdark madness can help u (i cant upload the file cuz my internet speed is to slow sorry) its on windows 7 m3 \common files\microsoft shared\inksome user confirm that it dont work on xp it will just need tablet pc files (api .dlls)and greetings amirz nice to be back :thumbsup_anim: yes u can post it anywhere jsut make sure about the credits :icon_cool:
December 4, 200816 yr thats what im saying it has a prob like thatdark madness can help u (i cant upload the file cuz my internet speed is to slow sorry) its on windows 7 m3 \common files\microsoft shared\inksome user confirm that it dont work on xp it will just need tablet pc files (api .dlls)and greetings amirz nice to be back :thumbsup_anim: yes u can post it anywhere jsut make sure about the credits :icon_cool:Nevermind, Lol thx alot Bro for this i've already posted your work in WinMatrix and given full credits to you there:http://www.winmatrix.com/forums/index.php?showtopic=21199Again thx alot Bro U rockn rooolll. Cant wait for myself to install damn Windows Seven in one of my PCs! :thumbsup_anim: To DaRk MaDnEsS and everybody here who's interested to get original Windows 7 MIP (Math Input Panel) in Xp, if your Xp is Xp Tablet PC Pro (or "Ultimate" XD like Bro Jdd's above) then you only need Alky 1.1 to patch the exe (with Vista Ultimate serial), usually done without any problem.If you have Xp Non Tablet/"Normal" (Pro, Home, MCE, Starter Edition, Embedded), beside Alky 1.1 to patch the exe (with Vista Ultimate serial for the set up), then you also need to install (All components below are Xp Tablet 2005 built-in features):- Net Framework 1.0 and/or . Net Framework 1.1 SP1 and Hotfix KB886903 -> Note: Xp Tablet PC and MCE 2005 has included .Net framework 1.0 as built in component and might be 1.1 for some OEM versions (please only choose one/higher):Download .net framework 1.1 :http://www.microsoft.com/downloads/details...;DisplayLang=enDownload .net framework 2.0 :http://www.microsoft.com/downloads/details...;DisplayLang=enDownload .net framework 3.5:http://www.microsoft.com/downloads/details...;DisplayLang=en- Windows Journal Viewer 1.5 -> (Xp Tablet PC 2005 doesnt need this)Download: http://www.microsoft.com/downloads/details...;DisplayLang=en- Microsoft Tablet PC SDK 1.7 -> (Xp Tablet PC 2005 doesnt need this)Download:http://www.microsoft.com/downloads/details...;displaylang=en- Microsoft Tablet PC Recognizer Pack: Download (80 Mb - MUI):http://www.microsoft.com/downloads/details...;displaylang=enNote: "Special Offer" For English Users Only: Download Lite version of Tablet Recognizer Pack (English Only- For only about 3 Mb, recompiled by me): English-US: http://www.4shared.com/file/61605471/ef2a9...rified=cc25d654 English-UK: http://www.4shared.com/file/61606098/1dc90...rified=cc25d654- Microsoft Tablet PC SDK Ink Analysis and Input Supplement (requires Tablet PC SDK 1.7 installed before) -> (Xp Tablet PC 2005 doesnt need them)Download:http://www.microsoft.com/downloads/details...;displaylang=enOr Just Google them, done.Then patch the mip.exe by using Alky context menu (patch and run Vista Executable) as usual to execute it. Done. Good luck n Enjoy!
December 6, 200816 yr AMIRZ what dll files you want i can get them for you just tell my and i would try and thx for both of you in making xp get more Vista and 7 AbilityOh sorry Bro i thought you only want know that how to install MIP in Xp or Vista, thx alot for your help DaRk MaDnEsS. Seems you have Windows 7 installed , The dlls i meant are co-dependent dlls for handwritten Mathematical recognition APIs for mip.exe that you may find it/them by using Dependency walker or other binaries tools for the calls (i dont know its/their name coz i dont have Windows 7 installed coz still no have time/space, maybe next year. Installing Windows 7 in VM maybe a good idea for virtualization/clean "sandbox", but i think it wont be so optimal since some drivers will still not work, include some virtual ones, as my previous experience) . However i still don't know how does Windows 7 environment like (maybe like Vista? The mip doesnt have the mui file (?). And might be some Windows 7 apps such as Notepad, Sticky Notes (i've got Windows 7 Sidebar from Ricktendo - Thx alot mate, but too bad i have tried it and still can't work so far even in Vista lol ). Thank u so much for your help Bro' DaRk MaDnEsS, im waiting for the code. May God bless U and Us to get them all working in Vista and/or Xp :thumbsup_anim: Ameen!... Edited December 6, 200816 yr by AMIRZ
