Posted November 21, 200816 yr NumerimalNumerimal is a numeral converter. It will convert between decimal, hexadecimal, octal, binary and any other user-selectable base up to 64-base. See some of the features listed below.Numerimal can: * Convert as you type, so no convert button is required * Be used as a stand-alone program using no dll's or registry settings * Remember last window position * Convert using the rarely used one-based conversion * Be transparent * Multi-Language SupportBest of all, Numerimal is FREE.@155 KB F11ECBEAE5F797908B591C09788DC2C4Note: Shortcut (destination directory) can be found under Utilities. AddOn is fully uninstallable.
