[Addon] Tune Up Utilities 2009 True Addon
Posted (edited)
Fast, Effective Windows Optimization
* One-click overview of your PC performance
* Quick analysis of your PC’s hardware, operating system, and programs
* Real performance increases, real fast
* Easy-to-understand help functions
Intelligent Windows Optimization Built in for Every PC
* Intelligent recommendations for your unique PC optimization
* Identifies your personal settings and protects them
* Highlights your PC’s optimization potential, including unused programs and resource-draining settings
* Recommends options and explains performance results before taking any action
Safe Windows Optimization
* Provides you with safe and effective optimization results
* Corrects all mistakes created from previous tuning attempts
* Comprehensive and easy rollback ability for any changes made to your PC
Perfectly Designed for Your Windows Operating System
* Automatically detects and configures for your operating system
* Ideal for XP and Vista (32/64 bit) users
* Designed to leverage the unique features within each operating system
you can add your own serial in the String section in the start of inf file
Program Version:2009 8.0.1100
Download
Md5: 71F777B85D76D906D1E24A1568FE598A
ChangeLog
24-11-2008(Final)
Added the Missing ShortCuts
Automatic Pc Tune-Up is enabled by Default
Fixed uninstall not removing Files
Fixed Some Registry
Added Some Missing Files.
Got some lines cleaned and removed Unneeded.
23-11-2008 (Beta2)
Fixed Product might be damaged Screen
Fixed some shortcut and added some more
Fixed A typo is some files names
Added some missing files during installation
22-11-2008(Beta1)
Initial Release
enjoy
Edited by DaRk MaDnEsS
Posted (edited)
Beta 2 Is out
plz test it and give me feedback
if any problem i would try to fix it
Edit:
The final Release would be out tomorrow all the problems i got are fixed
Just Couple of more tests and time to upload and every thing is ok after that
thx for using my own addons
Edit 2:
All problems got fixed Just last check and tomorrow the Final Version would be released
thnx, looking forward for the final release!
thx for your Support and Final Release is out now :icon_cool:
I like your work. Will test this in my next vm ;)
thx i`m just a newbie trying to prove him self a little :sweatingbullets:
and thx for your tests :thumbsup_anim:
  • 5 months later...
Download
ChangeLog
enjoy
Hi Dark!
Ther are new version of Tuneup -> TuneUp Utilities 2009 8.0.3100.31
Addon of jamesbbaby in other section d'ont fun!
I would like you addon (escuse my bad englsih)
[ ]'s Thx!
DaRk MaDnEsS
Ther are new version of Tuneup -> TuneUp Utilities 2009 8.0.3300.1
I already tried to mount several times this addon, even using the Borland Delphi DLL Resources, but I am encountering difficulties. Can you help me?
Thx.
Posted (edited)
well about the new version i would work on it in a couple of days
i will release the Svcpack Addon i use recently
and in a few days i will try to update this version as well
LUZR4LIFE
What's "lurker" ?
Sorry I'm newbee...
where did you see that word
i might get it if i see it's place
